27 novembre 19, 14:34 | #751 (permalink) Top | |
User Data registr.: 27-04-2006 Residenza: Zanica (Bg)
Model aircraft The impact of the new regulation on model aircraft operations is very limited and the hobby pilots will still be able to perform the same operations as they do today. EASA recognises the pro-safety environment created by model clubs and associations, documented in the positive safety records. In this way, several options for recreational activities are defined: • operating as members of a model club or association that has received an authorisation from the competent authority which allows to deviate from the provisions of the regulation; • operating in a special zone defined by Member States where certain requirements do not apply and/or where the operational limitations are extended, e.g. increased height limitation; • and, in case you are not a member of a model club or association and there are no special zones in your vicinity, you can still operate your model aircraft respecting the operational limitations defined for C4 class.Find more information in our proposed consumer information: http://www.easa.europa.eu/easa-and-y...il-drones-rpas (downloads) Sul rosso partono le risate automatiche | |
27 novembre 19, 14:58 | #752 (permalink) Top |
User Data registr.: 08-05-2012 Residenza: Trieste
| ...o ringiovanendo, visto quanto scorrettamente scrivono alcuni giovani.
__________________ ELI:mCPX,Solo Pro228A,V911, E160#AEREI:ApprenticeS15e, CESSNA400Corvallis,TurboTimber 1,5m,Rare BEAR 0,9m,UMXTurboTimber#BARCHE:USAF Rescue Boat,Airboat tattica,Hovercraft Griffon 2000TDX,PT-109,LCM-3,costruiti da zero#TX:SPEKTRUM DX6i,DX8, FLYSKY FS-GT3B. |
27 novembre 19, 18:06 | #753 (permalink) Top | |
User Data registr.: 19-01-2005 Residenza: 33170 e dintorni
se ci arriva.
__________________ Trattiamo bene la terra su cui viviamo: essa non ci è stata donata dai nostri padri, ma ci è stata prestata dai nostri figli | |
27 novembre 19, 18:09 | #754 (permalink) Top | |
User Data registr.: 21-05-2009
Perché tra gli uni e gli altri c'è la stessa attinenza che c'è tra un autoveicolo e un'imbarcazione... Dronisti...ne sentivamo la mancanza... | |
27 novembre 19, 18:39 | #755 (permalink) Top | |
User Data registr.: 18-12-2009 Residenza: biella
Il trasponder dovrebbe servire solo per permettere di vedere se l"attività di volo vista per caso da una pattuglia che va magari in giro per altri motivi é regolare.......se il modello visto in volo é in regola sulla App appariranno i dati di modello e pilota....... .....se non apparirà nulla saranno augelli per diabetici......... | |
27 novembre 19, 18:40 | #756 (permalink) Top | |
27 novembre 19, 18:44 | #757 (permalink) Top | |
Forse anche Leonardo ha proposto qualcosa........ chissà cosa ne verrà fuori...... | |
27 novembre 19, 18:46 | #758 (permalink) Top | |
27 novembre 19, 19:13 | #759 (permalink) Top |
Sospeso Data registr.: 17-07-2016
Da alcuni post (non da ora, purtroppo) sembrerebbe che il primo interesse e la prima occupazione di alcuni, ma già TROPPI, aero-utenti (termine inventato ora ora da me per definire chi fa volare qualcosa di radiocomandato non importa cosa) sia quella di sfuggire ai caramba e di volare in luoghi e in modalità appositamente scelte tra quelle più vietate, possibilmente sghignazzando sinistramente nel frattempo. Rivedendo gli eventi di questo ultimo lustro, non è che atteggiamenti del genere abbiano già provocato ABBASTANZA danni e rotture di zebedei? La regolamentazione che sta venendo fuori con fatica non è poi così malaccio, dati i presupposti. Sembrerebbero essere valorizzati i club (OTTIMA cosa) senza penalizzare del tutto i "battitori liberi" che pure sarebbero stati un valido motivo per mettere tutti a terra o quasi. Quindi, perchè ricominciare con i sofismi dell' automatico- autonomo- posso fregare la localizzazione eccetera? Perchè mettere nuove pulci nelle orecchie? |
27 novembre 19, 20:58 | #760 (permalink) Top | |
Caxxo.........mi tocca dare ragione al Nencioni....... | |
avvicinamento f3k | sifer | Categoria F3K | 9 | 21 agosto 12 17:37 |
