Vecchio 09 settembre 16, 14:09   #1 (permalink)  Top
L'avatar di TeoDaOlmo
Data registr.: 05-10-2011
Residenza: Venezia, Trento
RadioLink AT9S
Ciao ragazzi, domanda da profano totale... secondo voi ha qualche ragione di essere acquistato questo radiocomando?
Main Features:
- DSSS and FHSS spread spectrum work simultaneously and provide extraordinary anti-interference performance.
- Astounding compatibility. It supports nearly all RC airplanes, boats, and cars.
- 3ms ultra fast response. The speed is more than 6 times faster than the average 20ms of other transmitters.
- Most advanced configuration.The STM32F103VET6 MCU with a 32-bit RISC core operates at 72MHz and has a 512KB of flash memory, two 12-bit ADCs. As for the TI CC2533 chip, it is the most advanced chip in an RC transmitter.
- Multilingual menu. 9 languages are available for you, including English, Chinese, Spanish, Dutch, French, Italian, Turkish, Russian and Korean.
- SBUS and PWM output. With R9DS Receiver, it supports the output of SBUS and PWM signals at the same time. In addition, it also supports any receivers in the RadioLink D Series, especially R10DS and R6DS.
- Green and low-consumption. Its operating current is only 90mA, which contributes to its long run time of more than 12 hours. The design of the AT9S PCB layout also effectively eliminates the interference of SMPS.
- Intelligent anti-reserve protection. When the battery is connected wrongly, there will be no electricity in the circuits. No matter how long the wrong connection lasts, you don't need to worry that this will do any harm to the transmitter.
- Discernibility of 4096-grade data. With the most advanced hardware design, the output of the servo signals is smooth, with the regular fluctuation of 0.5us and maximum fluctuation of 1.84us, which is 4 times as precise as the AT9 Transmitter.
- User-friendly prompts. It ensures a safe flight by providing you with various alarm prompts, such as low RSSI vibration alarm setting, low transmitter voltage, low receiver voltage and low extended engine voltage alarm.
- Online upgrades via USB. With a USB cable, your AT9S Transmitter remains the frontrunner forever! It is easy to copy a huge volume of the model data. The resetting of the parameters can be done by bulk copying.
- A menu that guides you. No instruction is needed. Following what the menu tells you to do is enough to complete all the settings.
- Programmable interface. Basic menu, advanced menu, graphs of data and so on are available for you. You can even edit your own control interface.
- Considerate and ergonomic design. The transmitter is sweat-resistant and durable after electroplating and sub UV-coating. It is also amazingly satisfying because it has a large number of switches, including 2 rotary knobs, 2 sticks, three 3-way switches, four 2-way switches, and one self-closing hinge.
Specifications:
Size: AT9S 183 x 100 x 193mm, R9DS 41 x 23 x 14mm
Weight: 0.88kg
Frequency: 2.4GHz ISM band ( 2400MHz to 2483.5MHz )
Modulation mode: QPSK
Channel bandwidth: 5.0MHz
Spread spectrum: DSSS, FHSS
Adjacent channel rejection: more than 38dBm
Transmitter power: less than 100mW ( 20dBm )
Operating current: less than 90mA at 12V
Operating voltage: 7.4 - 18.0V
Control distance: more than 900 meters near the ground, 1500 meters in the air
( The actual control distance depends on the environment of flight. )
Channel: 10 channels ( more than 5 user-customizable channels )
Compatibility: all 120-degree and 90-degree swash-plate helicopters, all fixed-wing planes, gliders, and multi-rotors
Simulation model: in this model, you can turn off the radio-frequency emission and enter the power saving mode
Screen: 2.8 inches, 16-bit color, 240 x 320 pixels
Compatible receivers: R9DS ( SBUS and PWM ) , R10DS and R6DS
Ho visto che è in offerta da Gearbest ad un prezzo molto buono (27,60€ in meno rispetto a ieri), sembra abbia un bel po' di funzioni, oltre a ben 10 canali e ad un'ottima portata (almeno sulla carta).. potrebbe essere un acquisto valido pensando di utilizzarla sia con multirotori che con elicotteri?
Cosa potrebbe dare in più o in meno rispetto al'ultra blasonato Turnigy 9x?
Attualmente io ho una banalissima XK X7, mi piacerebbe avere tra le mani di qualcosa di più professionale, universale e di qualità, e che possa essere compatibile anche con i futuri acquisti.
Grazie a tutti per le spiegazioni!
Non è la misura del trattore che conta, ma quanto tempo trascorri ad arare il campo...
TeoDaOlmo non è collegato   Rispondi citando
Vecchio 09 settembre 16, 18:00   #2 (permalink)  Top
Moderatore
L'avatar di klamath
Data registr.: 20-09-2005
Residenza: ɐuƃoloq
Invia un messaggio via ICQ a klamath
Originalmente inviato da TeoDaOlmo Visualizza messaggio
NO
ogni tanto qualcuno chiede consigli su questa radio, se cerchi nella sezione radiocomandi trovi sicuramente altre discussioni
Il nuovo forum riservato ai Multirotori è ONLINE...
>>> https://www.dronerc.it/forum/ <<<
Pack suoni completo con varie voci e per tutte le versioni di opentx.
https://github.com/klamath1977/opentx-HQ-italian-vp
klamath non è collegato   Rispondi citando
Vecchio 10 settembre 16, 00:08   #3 (permalink)  Top
Grazie, provo a cercare meglio allora, mi aveva incuriosito...
Vecchio 25 novembre 16, 19:24   #4 (permalink)  Top
Data registr.: 02-10-2012
Residenza: trapani
AT9S Radiolink come funziona
perchè comprare questa radio?
ALLORA
1 costano pochissimo le riceventi con telemetria vantaggio: risparmio totale
2 ha una alta qualità di decodifica trasmissiva
3 ha la decodifica riconosciuta legale in italia esempio assicurazioni droni e gare a norma per fpv ed aerei
4 ha una distanza di controllo accettabile
5 solo la ricevente senza aggiungere altri aggeggi ti dà la tensione lipo del drone o aereo avvisandoti con allarme bip e vibrazione sul radiocomando. e sopratutto il controllo del segnale radio chiamato RSSI che riceve la ricevente, cui si puo' impostare un valore di allarme BIP E VIBRAZIONE sul radiocomando , UTILE IN FPV se hai gli occhiali almeno senti gli allarmi.
forma bellissima tranne il colore oro
6 ergonomica
7 display menu in italiano e a colori
8 economica nel prezzo
enzovolo1 non è collegato   Rispondi citando
Vecchio 26 novembre 16, 14:47   #5 (permalink)  Top
Moderatore
L'avatar di klamath
Residenza: ɐuƃoloq
Originalmente inviato da enzovolo1 Visualizza messaggio
ALLORA
1 prezzo allineato con tanti altri brand, FlySky in primis per economicità di riceventi e sensori telemetrici, non da meno per reperibilità dei componenti che si trovano dappertutto ma non si puo dire lo stesso della radiolink
2 perché non ci dici di più su questa presunta "alta qualità di decodifica trasmissiva"? spiegaci anche come sei certo di questa alta qualità, che altri sistemi conosci, i termini di paragone quali sono?"
3 come sopra... dato che la elogi tanto dicci di più di questa "DECODFICA" perché detta cosi sembra una frase buttata li da uno che l'ha sentita dal cugino dell'amico...
4 raccontaci, che test e prove hai fatto?
5 telemetria nella norma come tante altre, tuttavia nulla di speciale ad esempio per dirne un paio, non supporta gli avvisi vocali, e a vedere il sito del produttore sembra non esistano sensori telematici
6 ergonomica
6 mai avuta tra le mani quindi non posso dire nulla a riguardo
7 il principale difetto dei radiocomandi col display a colori è che all'esterno il display diventa illeggibile, questo com'è?
8 punti di vista.... personalmente preferisco spendere qualcosina in piu e avere mooolto di piu
per il resto degustibus...
Ultima modifica di klamath : 26 novembre 16 alle ore 14:52
Vecchio 27 novembre 16, 20:34   #6 (permalink)  Top
Residenza: trapani
Infatti! Nel punto 8 cioè alla fine, ti sei risposto da solo
( 8 punti di vista.... personalmente preferisco spendere qualcosina in piu e avere mooolto di piu)
Quindi oltre a questa radio tu spendi di piu.!!?!
Io mi accontento per il basso costo e per quel che cerco in una radio ,quindi per Me va piu che bene.
Prima di questa radio ho avuto
Hitech sport 6 .....prezzo di una sola ricevente 49€
Turnigy x9r pro (con modulo frsky e ricevente 39€ con telemetria)
Spektrum dx6 ....costo ricevente base ar610 - 48€
Tutto questo contro le 9€ di ricevente originale r9ds venduta su wish o su aliexpress.
Vecchio 30 novembre 16, 23:46   #7 (permalink)  Top
L'avatar di dtruffo
Data registr.: 21-10-2003
Invia un messaggio via MSN a dtruffo
Ok. Abbiamo capito tutto.
Associazione Sportiva GRUPPO AEROMODELLISTICO VST - Volare su Tetti http://www.vst-aero.it - Per i poco intelligenti non indica 'i tetti', ma il Comune in cui ha sede il campo volo (Tetti Neirotti) che dista piu' di 750 mt. dalla pista.
dtruffo non è collegato   Rispondi citando
Vecchio 30 novembre 16, 23:55   #8 (permalink)  Top
Data registr.: 30-12-2007
Residenza: pisa
Noi abbiamo capito tutto.....ma lui non ha capito una mazza!!!
Prima di tutto nessuno ti ha chiesto degli aggiornamenti ma io soprattutto ti ho fatto delle domande precise alle quali hai tranquillamente glissato!
MI viene anche il dubbio che tu abbia un altro nick per poterti domandare e risponderti riguardo questa radio......
Ma credo in maniera ancora più ferma che tu sia un venditore di queste radio!
esponenziale non è collegato   Rispondi citando
Vecchio 01 dicembre 16, 00:31   #9 (permalink)  Top
L'avatar di Alexio
Data registr.: 06-11-2014
Residenza: Como
mentre se non gareggia non è un professionista ma solo un OBBISTA a cui consiglierei una radio come questa.
Ma non si scrive Hobbista? 😄😄😄😄😄😄🤔🤔🤔🤔😀🤔
Alexio non è collegato   Rispondi citando
Vecchio 01 dicembre 16, 17:54   #10 (permalink)  Top
Residenza: trapani
Rieccomi
Ho sempre pensato che questo sito fosse utile a tutti per le informazioni che esso contiene grazie al fatto che ogni uno di noi publica le proprie esperienze e delucidazioni su prodotti HOBBISTICI RC.
MA!...a quanto sembra alcuni di voi che hanno penalizato il mio poco sapere sul prodotto in questione (vedi pagina 1 e 2) invece di lasciare spazio a chi veramente crede sul baronerosso, crea scompiglio e voglia di cancellarsi da tale sito in modo da non dare piu info al publico dominio.
Spero veramente che anche voi un giorno avrete necessità di chiedere qui su baronerosso e vi ritroverete le porte chiuse.
AVVISO ai possessori di radiolink At9s
Spostiamoci in un altra ricerca sempre qui su baronerosso
----------QUI STOP INFO AT9S-----------
Radio RADIOLINK franchinello Radiocomandi 3 11 settembre 15 11:14
RadioLink AT-9 2.4G 9CH RC Transmitter Tommyxx Radiocomandi 1 01 agosto 15 16:25
info su radiolink at9 THEQUILA1 Radiocomandi 1 25 febbraio 15 18:01
Radiolink t6hp and983 Elimodellismo Principianti 4 14 marzo 12 14:43
TX Radiolink T6EHP-E 2.4GHz Stefanone Compro 0 23 marzo 11 17:08
Tutti gli orari sono GMT +1. Adesso sono le 17:38.
