Vecchio 13 agosto 10, 23:12   #1 (permalink)  Top
L'avatar di Tamanaco
Data registr.: 08-05-2004
Residenza: Provincia Forlì-Cesena e volo dove si può...
Arrow NO lipo su TX JR 2.4...
Per chi usa, o chi vorrebbe usare o solo per per chi vuole sapere se......
Estratto dal manuale originale JR (in questo caso della DSX9 ma vale anche per la 9XII), vedi in rosso:
PS: io uso 8 stilo eneloop da 2000, bastano, avanzano e ridondano....
Tips on Using 2.4GHz Systems (Continued)
The wrong model has been selected in the model
memory (Model Match)
The transmitter is near conductive material
(transmitter case, truck bed, etc) and the re.ected
2.4GHz energy is preventing the system from
connecting (See Q2)
The bind button was unknowingly (or knowingly)
depressed and the transmitter was turned on
previously, causing the transmitter to no longer
recognise the receiver.
Q5:
Can I use a 3-cell Li-Po pack in my transmitter?
A5:
No. All current JR transmitters are designed to
operate using a 9.6 volt transmitter pack. A fully
charged 3-cell Li-Po pack puts out 12.6 volts. This
higher voltage can over load the power-regulating
transistor causing damage and or failure, possibly in
.ight. Many of our customers have experienced
failures using 3-cell Li-Po packs and their use in JR
transmitters is highly advised against. The DSX9 2.4
system will operate for over 8 hours using a 1500mAh
Ni-MH battery.
Tamanaco non è collegato   Rispondi citando
Modalità elencata Modalità elencata
LIPO Monitor/LIPO Saver sul Kyosho Caliber M24 Helycopter Elimodellismo Motore Elettrico 9 20 dicembre 05 11:18
Tutti gli orari sono GMT +2. Adesso sono le 07:55.
