Vecchio 11 agosto 11, 21:21   #2201 (permalink)  Top
Coordinatore dello staff
L'avatar di staudacher300
Data registr.: 16-02-2004
Residenza: Roma Snakes Hill
Originalmente inviato da pedro978 Visualizza messaggio
Ma la versione 2.03 ha anche aggiunto delle novità nella programmazione oppure queste miscelazioni si possono fare anche con le versioni precedenti?
Mi sa che devo cercare una guida dettagliata su come programmare la DX8.....
La 2.03 introduce novita' interessanti, come dal seguente elenco:
Version 2.03
Software Features
Changed Monitor screen to improve perceptibility of changes in stick and trim
resolution.
Added new wing type Elevon B. This mode is used if control horn or servo
positions don’t allow correct throw directions. Eliminates need to swap elevator
and aileron servo leads. Also required with some trainer systems like the DX6i.
When editing the timer configuration, any changes will cause the timer to be
reset.
After reversing the throttle channel, the screen changes to show a reminder to
rebind at low throttle for safety.
To improve the ease of adjusting travel limits for complex servo functions (swash,
V-tail, etc), the Servo Setup screens now are tracking servo outputs directly.
To avoid confusion when binding, we changed the Bind screen to show actual
11ms/22ms bind info instead of what the receiver is capable of doing.
Enabled adjustment of the telemetry receiver voltage display bar. Adjusting the
low and high setpoints (high is NOT an alarm) you are adjusting the scaling of
the bar graph for Rx Voltage.
When importing a model, a confirmation screen now appears to warn about
possibility over-writing the wrong model.
Changed telemetry menu and capabilities to enable access to future sensors.
Users are now able to calibrate the knob and both stick in both axes. This is
done by selecting NEXT several times from the System Setup menu. Move the
sticks in a “+” format, NOT in an X or O. It is important not to push the sticks to
the corners.
Software Corrections
Flap/Elevator Smoothness – Elevator compensation travel was not smooth
when there was significant trim on the elevator channel.
Flap Overdrive – Initial flap movement could sometimes cause flaps to jump to
one extreme of travel before moving to correct setting.
Telemetry - Changed scaling for telemetry alarms Altitude & Airspeed. Fixed
‘hidden status’ screens when using models created in older versions.
Translations – Improve/Correct translation of some terms for German, Spanish
and Italian modes, particularly on the Timer and Telemetry screens.
Vecchio 12 agosto 11, 08:11   #2202 (permalink)  Top
L'avatar di giuse1966
Data registr.: 07-11-2008
dx8
La radio l'ho programmata il giorno dopo averla acquistata, le migliorie fatte sul software non hanno mai modificato i settaggi fatti in precedenza. "staudacher300" ha descritto nel dettaglio la 2.03
giuse1966 non è collegato   Rispondi citando
Vecchio 12 agosto 11, 09:51   #2203 (permalink)  Top
L'avatar di double68
Data registr.: 27-05-2009
Residenza: Piacenza
Originalmente inviato da giuse1966 Visualizza messaggio
Importante, grazie giuse1966 !
Vecchio 12 agosto 11, 17:41   #2204 (permalink)  Top
L'avatar di magnetron1
Data registr.: 26-12-2009
azz... questa me la sono persa...
è uscita la v2.03?
vale la pena aggiornare? io ho ancora la v2.01 aggiornata in casa madre...
che mi consigliate?
AERODRONE M4X - AERODRONE M6S (revamping) - AERODRONE M4H - i miei video
magnetron1 non è collegato   Rispondi citando
Vecchio 12 agosto 11, 19:19   #2205 (permalink)  Top
Residenza: Piacenza
Qualcuno ha già avuto esperienza con il sensore di temperatura a corredo con la DX8. Il cavetto con relativo sensore se lo aggancio alla testa del motore, es: il mio supertigre, resiste alle temperature di esercizio di un motore a scoppio o lo sciolgo? Faccio questa domanda perché la guaina del cavetto "sensore temperatura" non mi sembra di quelle resistenti alle alte temperature... Sbaglio?
Attendo lumi...
Vecchio 12 agosto 11, 21:06   #2206 (permalink)  Top
L'avatar di moscaleras
Data registr.: 18-10-2008
Residenza: palermo
valori telemetria
salve, che valore avete dato sulla telemetria al frame e hold?
Vecchio 12 agosto 11, 23:10   #2207 (permalink)  Top
Residenza: Piacenza
Se intendi come allarme io ho dato valore 1 all'Hold che é lo sgancio completo del segnale e 20 come soglia di frame. Ricordo che dopo un tot di frame persi in sequenza continua la ricevente sgancia dalla TX.
Il primo non si dovrebbe mai verificare e il secondo solo raramente e mai in quantità consistente.
Info sul cavetto del sensore di temperatura? UP
Vecchio 12 agosto 11, 23:21   #2208 (permalink)  Top
Attendo lumi...
Il cavo in questione è fatto apposta per sopportare temperature elevate e va avvolto sulla testata con il sensore (l'unità centrale) rivolta verso l'alto.
Vecchio 13 agosto 11, 09:43   #2209 (permalink)  Top
Residenza: Piacenza
Originalmente inviato da magnetron1 Visualizza messaggio
Ok, provvedo. Grazie
Vecchio 13 agosto 11, 18:53   #2210 (permalink)  Top
Residenza: Piacenza
Ho avvolto il sensore sul cilindro nella prima aletta sotto la testata, il valore massimo indicato dalla telemetria durante il volo é circa 80 gradi, penso che in realtà il motore scaldi di più considerando che l'aria spinta dall'elica investe anche la sonda.
Dimenticavo il motore é un supertigre 40.
Cosa ne pensate???
Tutti gli orari sono GMT +1. Adesso sono le 05:14.
