Vecchio 03 aprile 09, 18:32   #51 (permalink)  Top
L'avatar di rillo75
Data registr.: 05-01-2008
Residenza: Bologna
in precedenza non mi hai risposto ........ hai letto e seguito qanto segue:
Binding Connection Explained
In order to accomplish a bind between the Spektrum receiver and transmitter, the signal pin on the BATTERY slot in the receiver must become grounded (connected to the Negative power lead).
No other servo slot in the receiver will allow you to accomplish the bind.
In order to accomplish this grounding of the binding signal pin, you must be using a three-wire battery switch harness. The three wires are the positive, negative, and signal leads. The Spektrum binding plug is a simple shorting plug, and merely places a [jumper] wire across the signal pin and ground (negative) pin.
A two-wire switch and wire harness will only connect positive and negative…but not the signal, and consequently will not allow binding to take place.
If your installation is employing a two-wire switch and wiring harness, as may be the case with some lithium battery and regulator systems, you [will need to] temporarily remove that two–wire harness from the system by unplugging it from the receiver battery slot. [You can plug your two wire harness into any unused channel in the receiver for this binding process, but remember you will need to RECONNECT it to the "Battery" connector in the receiver AFTER binding- Ed.]
Plug in the three-wire switch, wiring harness and battery that came with the radio and proceed with the binding as per the instruction manual. After the binding is successful, you may remove the Spektrum three-wire switch and harness and reinstall your two-wire system.
Keep the three-wire switch and harness handy for any future binding that may be required.
The Spektrum receiver does not care at all about what sort of battery technology is delivering the power:… Lithium, NiMh, NiCd, A123, etc etc, but it absolutely demands that you accomplish the grounding of the binding pin in order to achieve a bind. [Remember the maximum voltage for the AR7000 is +9volts - Ed]
Capt Jim (RCU Username)
[Editor comment - Capt Jim graciously shared his experience, and I added a couple of comments for clarification. His explanation is perfect - "Binding" requires that signal pin to be connected to the negative battery lead; how that happens is almost irrelevant, but it MUST be the signal pin from the "Battery" connector slot in the AR7000!! ]
....diffidate sempre dagli aeromodellisti da tastiera
http://www.aeromodellisti-aecibologna.it/
rillo75 non è collegato   Rispondi citando
Vecchio 04 aprile 09, 14:38   #52 (permalink)  Top
Data registr.: 07-07-2007
Ma è riferito al mio caso? Non ho capito.
Io ho usato per il binding lo switch a 3 vie fornito dalla spektrum, l'unica cosa è che invece di attaccare la spinetta alla batteria, che non ho, l'ho attaccato alla spinetta del regolatore che è attaccato alla batteria LIPO del modello.
fedeskr1 non è collegato   Rispondi citando
Vecchio 04 aprile 09, 16:47   #53 (permalink)  Top
Data registr.: 27-03-2007
Ciao ragazzi...dopo doverse prove posso dire che il 2.4ghz e fantastico!!!
mi sono accorto di una cosa che pur non compromettendo per niente il funzionamento del sistema mi ha lasciato qualche dubbio: come ho già detto ho la DX7 spektrum con ricevente ar7000, la cosa strana è che avvicinando l'antenna della tx alla rx la luce della rx madre si spegne mentre quella del satellite resta accesa. Per quanto riguarda il funzionamento come ho detto non cambia niente infatti risponde a tutti i comandi.
Devo aggiungere inoltre che avvicinando l'antenna tx al satellite la luce del satellite non si spegne come la madre...
a voi fa così?
Michele88 non è collegato   Rispondi citando
Vecchio 05 aprile 09, 01:02   #54 (permalink)  Top
Data registr.: 09-06-2008
Residenza: Verona
Originalmente inviato da fedeskr1 Visualizza messaggio
Prova ad usare una NORMALISSIMA NiMh da 4 o 5 celle, regolarmente caricata e vedrai che non avrai più alcun problema di binding !
Inoltre, rispondendo a Michele88, non sò cosa intendi per "avvicinare la radio" ma tieni presente che è buona norma tenere il TX ad almeno un metro dalla RX; accostandoli, potresti indurre un segnale all'ingresso del ricevitore talmente forte da danneggiare il GaSFet del front end, rendendolo "sordo".
Per la programmazione del fail safe, seguendo pedestremente le indicazioni di pag. 18 del manuale, usando una batteria ricevente normale carica e l'interruttore originale NON POTETE sbagliare.
La posizione dei controlli del TX durante il binding diventerà quella dei servi in condizione di fail safe.
Ricordate che nella ricevente AR7000 il canale preposto al comando "binding" è solamente quello della batteria, ergo è INDISPENSABILE usare interruttori con tutti e tre i fili cablati (negativo, positivo, comando o se preferite marron, rosso, arancio): in alternativa alimentate la RX attraverso un canale libero e mettete il ponticello di binding direttamente nella ricevente nella presa "battery", e NON in altri canali.
Renzo
Un bel tacer non fù mai scritto....
Ultima modifica di re60cnc : 05 aprile 09 alle ore 01:10
re60cnc non è collegato   Rispondi citando
Vecchio 06 gennaio 13, 11:38   #55 (permalink)  Top
L'avatar di PILOTA-3000
Data registr.: 13-12-2011
Residenza: BARI
aiuto problema ricevente!
Ciao a tutti, ho un problema con la ricevente orange 4ch.. Connetto lo spinotto per il binding sulla ricevente poi gli do alimentazione, e non lampeggia il led! ma rimane fisso! come faccio ora a bindarla sulla mia DX6i? AIUTOOOOOOO
PILOTA-3000 non è collegato   Rispondi citando
Dx6i e Blade 400 binding darkfener Elimodellismo Motore Elettrico 4 13 marzo 09 17:23
Ar7000 Binding A Polarita' Invertita - Dilemma ciccioriccio82 Radiocomandi 2 22 gennaio 09 11:25
Binding - Governor baracca1 Radiocomandi 0 30 novembre 08 08:02
Swash -governor - Binding -trex baracca1 Elimodellismo Principianti 1 29 novembre 08 09:16
BINDING Spektrum DX6i baracca1 Radiocomandi 5 22 novembre 08 14:52
Tutti gli orari sono GMT +1. Adesso sono le 10:59.
