30 agosto 12, 00:56 | #21 (permalink) Top |
User Data registr.: 30-04-2012 Residenza: Buscate, campo del GAB Busto
[I]Tratto dal "trimming chart di Peter Goldsmith" Dynamic Balance Ok, were happy with our CG. The next trim step is dynamic balance. This is really only relevant with wing tip weight. Most other axes on a model aircraft are not affected too much by the dynamic effects of high g loads. But the wings are. Just because they both weigh the same and dont carry any aileron trim doesnt mean you cant have a wing weight problem. I have seen a myriad of ways to test for wing weight trim. Loops, pulling to vertical, and so on. My suggestion is to think about the sequencing argument. If you do loops, or pull to a vertical upline, the engine thrust can have an effect. But we havent trimmed our thrust angles yet, so how do we check this? Think about it, what could you do to check your wing tip weight in flight that will not be affected by thrust? Some of you may have figured this out already but what I do is put the model into a vertical dive with the throttle back (minimum of 3 4 seconds) and pull a hard corner at the bottom. No matter where your wings are in roll, when you pull to level, the wings must be level. Check this concept with your stick plane. It really doesnt matter where your wings are. As you pull to horizontal flight your wings must be level. If you attempt to pull a hard vertical from horizontal, you must be absolutely sure your wings are perfectly level. I dont know about you guys but I am not that good! If you go from vertical to horizontal, not only will the engine thrust have no effect, but your wings can be anywhere as youre on a vertical down line. When you pull the corner, the aircraft may be pointing in a different direction than you planned, but that is okay, as long as the wings are level. Now I know when some of you try this experiment you will notice one wing will consistently drop. You may have to add some weight to the opposite wing tip. I was never really sure if my tip weight was correct until I went to this method. Make sure you only use elevator through the corner. Perhaps, just for the trimming process, you can increase the aileron stick tension to ensure that you dont accidentally input a little aileron with the elevator and the elevators track correctly when you pull the stick back. Dont be quick to make a decision! Have patience and have a friend observe the proceedings. Do many pull outs and make absolutely sure before you move on to the next step of trimming.[/QUOTE] Ciao Obelix, Finalmente ho avuto tempo di leggere il passaggio di Goldsmith che hai riportato. La mia opinione è che questo non è un buon test, in quanto non riesce ad isolare il problema. L'uscita da una brusca cabrata alla fine di una picchiata può essere molto influenzata da diverse questioni. La prima è la posizione delle ali. E' facile dire di uscire con le ali in piano, ma poi bisogna vedere come lo fai. Poi è molto influenzato dalla velocità di uscita. Io penso sia meglio gestire il problema del bilanciamento laterale in modo statico e quindi sospendere il modello per l'elica ed il carrello e vedere se tende a buttare giù un'ala, presupponendo naturalmente che sia stato costruito in modo perfettamente simmetrico. Il test dinamico per verificare il bilanciamento laterale mi sembra veramente poco affidabile. In volo il modello tenderà a buttare giù un'ala in pre-stallo semplicemente perchè la velocità di sostentamento di quell'ala è più bassa di quell'altra e questa situazione può essere influenzata da una quantità di fattori. Voi cosa ne pensate? Manrico |
30 agosto 12, 08:08 | #22 (permalink) Top | |
User Data registr.: 06-10-2007 Residenza: Roma
il mio secondo nome è "san tommaso" Mi piace sempre verificare personalmente le soluzione prospettate ed è per questo che voglio provare il suggerimento del volo rovescio. Nel caso di specie quando ho bilanciato lateralmente il mio Sbach 2.2, ho fatto le prove suggerite da Goldsmith ed ho aggiunto man mano dei piccoli pesi sull'estremità alare (fissati con nastro) fino ad essere soddisfatto. Poi una volta in officina ho tolto i pesi e verificato in modo statico (metodo da te suggerito), il risultato finale è sempre stato 15 grammi sull'ala dx. Da qui mi sono "fatto persuaso", come direbbe Montalbano che il metodo di Goldmith porti ad un risultato sufficientemente veritiero. p.s. bellissimi questi thread "tecnici" con scambio di esperienze, suggerimenti, e consigli. Grazie | |
30 agosto 12, 09:34 | #23 (permalink) Top | |
User Data registr.: 20-02-2009 Residenza: viterbo
dalla discesa verticale mentre cabri bruscamente per riportare l'aereo in orrizzontale,inserisci una complicazione(se cosi' si puo chiamare) per la veridiera prova "IL CABRA",negli aerei di ultima generazione dove i pianetti di coda sono separati,cabrando,basta che un pianetto non sia in linea con l'altro(per esempio uno 20° e l'altro 23°) la prova sarebbe già falsata. preferisco lunghi rettilinei,in rovescio(ad aereo lanciato) senza dare nessun comando(quindi senza influenze esterne a falsare la prova). bisogna precisare che queste prove vanno fatte piu volte,e sopratutto in assenza di vento,fino a trovare un buon compromesso,e che la messa a punto piu importante e quella a terra(statica) e | |
30 agosto 12, 11:36 | #24 (permalink) Top | |
Detto questo, uno che cerca il corretto bilanciamento laterale con pianetti a 20° e 23° farebbe meglio a spendere il proprio tempo in altro Mentre ti chiedo se potessi descrivermi meglio la "tecnica" della tua prova. Nei lunghi rettilinei di cui parli, sei senza alcun comando ? sostieni il modello nel volo rettilineo o lo lasci scendere ? poi se non ho capito male sei anche con motore al minimo ? Grazie e saluti | |
30 agosto 12, 12:44 | #25 (permalink) Top |
User Data registr.: 24-03-2008 Residenza: Trapani
Chiedo, se abbiamo impostato il differenziale negli alettoni, vuol dire che quando diamo comando agli alettoni uno si muoverà più rapidamente dell' altro. In una manovra in pre stallo, utilizando gli alettoni , questa impostazione non può provocare che un' ala rispetto ad un' altra sia più reattiva? Spero d'essermi fatto capire. |
30 agosto 12, 14:50 | #26 (permalink) Top | |
per verificare anche questo(piani di coda allineati)in volo, c'è una procedura che si usa nel 3d,è quella di fare un looping strettissimo e vedere se l'aereo esce con le ali perfettamente livellate. per quanto riguarda la prova del volo rovescio,io la eseguo in questo modo: mando il modello ad una quota di sicurezza,faccio il volo rovescio a mezzo gas diciamo,dopo di che,tolgo il gas e non do nessun comando,ed osservo l'aereo in planata rovescia ( diciamo) come si comporta,se prosegue con le ali livellate,ho a la tendenza di buttare giu un'ala(anche se di poco) a quel punto aggiungo peso all'altra ala,finche non vola livellato.naturalmente dovrai fare piu prove,e magari in assenza di vento. spero di essermi spiegato | |
30 agosto 12, 14:56 | #27 (permalink) Top | |
per le manovre prestallo(3d) non credo si utilizzi il differ.. ma il max delle corse sia up che down. almeno credo | |
30 agosto 12, 21:26 | #29 (permalink) Top | |
Quindi in un volo misto f3A- Freestyle sarebbe opportuno avere il differenziale sugli alettoni sotto interruttore. Penso all'arrier, in quanto voli a bassissima velocità, stai attaccato all' elevatore e vai usando gradualmente alettoni e direzionale o al rool harrier sempre a bassa velocità e con cambi di rozione. Se devo essere sincero, non ho mai usato il differenziale sugli alettoni, anche se nel volo teso e pulito per i tonneau sarebbe il caso di provarlo per eliminare certe tendenze..... Proverò sotto interruttore. | |
31 agosto 12, 22:11 | #30 (permalink) Top | |
User Data registr.: 02-07-2004 Residenza: Ronchi dei Legionari (GO)
F3M italia | AntonioMonetti | Aeromodellismo Volo 3D | 21 | 12 novembre 12 00:36 |
F3A: "Voglio essere un Pilota F3A o F3M?" | Manrico | Aeromodellismo Categorie | 1 | 10 giugno 12 23:42 |
problema di bilanciamento/trimmaggio | lion89it | Aeromodellismo Principianti | 18 | 27 aprile 07 15:11 |
Test batterie F3A | Maxir | Aeromodellismo Categorie | 25 | 28 marzo 07 00:24 |
