Vecchio 17 dicembre 19, 08:06   #111 (permalink)  Top
L'avatar di manfredviii
Data registr.: 18-07-2007
Residenza: Condino
Originalmente inviato da rosnik Visualizza messaggio
Dimenticavo...
The firmware ha il tuo modulo interno o esterno?
Deve esser superiore o uguale a v.1.2.1.85 altrimenti và aggiornato con USB-to-serial adapetr.
Considerate che JumperTX è morto,
e quindi passare a OpenTX è indispensabile comunque.
A tal proposito è uscito un comunicato JumperXYz:
Recently, many T16 owners are asking for how to update their radio from JumperTX into openTX.
Firstly, we'd like to take this opportunity to express our gratitude to openTX team and Pascal Langer. Many thanks for your great job!
And to update your T16 from JumperTX into openTX:
1) Please check the version of your JP4IN1 module at the page of T16 model set up. Any module that is under version V1.2.1.85 will need to update it into the version V1.2.1.85 or above.
2) If your module version is V1.2.1.85 or above, you can update the radio firmware directly. Here is a video of showing how to do it: https://www.youtube.com/watch?v=BXhLk_l6280&t=281s (Many thanks TMac for the wonderful video)
How to update the module firmware:
1) If you are still using external JP4IN1, you can connect the module with USB to PC and update the firmware.
2) If you are having internal JP4IN1, and the version is under V1.2.1.85, you'll need a USB-to-serial adapter.
3) Here is a video of showing how to do it: https://www.youtube.com/watch?v=Dex92d7IQWI&t=44s (Many thanks TMac for the wonderful video)
USB-to-serial adapter, if you can't find the adapter in a local shop:
1) Jumper will offer the adapter free of charge. And you'll be in charge of the shipping cost.
2) You'll able to find the adapter on Jumper Aliexpress store. We'll share the link of the adapter on Facebook once it is available. Estimate in 2 - 3 weeks.
3) We'll need photos of your T16 S/N# and the screenshot of the module version before sending the adapter.
Here you can download the radio firmware: https://www.jumper.xyz/portal.php?mod=view&aid=17
Or you can download it from openTX website.
Last but not least, the firmware update is not needed if the radio is working all good. Only proceed if you know what you are doing. Updating firmware incorrectly may void the warranty.
grazie mille dell'assistenza.
Stasera provo
manfredviii non è collegato   Rispondi citando
Vecchio 19 dicembre 19, 19:22   #112 (permalink)  Top
Residenza: Condino
Dimenticavo...
Che firmware ha il tuo modulo interno o esterno?
Sono in difficoltà.
Io ho il modulo esterno JP4in1-SE quello che è arrivato assieme alla radio.
Non riesco a capire dove trovare il firmware da installare (e neanche come verificare quale versione di firmware è adesso).
Vecchio 19 dicembre 19, 21:01   #113 (permalink)  Top
L'avatar di rosnik
Data registr.: 30-04-2012
Residenza: Brescia
Originalmente inviato da manfredviii Visualizza messaggio
Sono in difficoltà.
La versione la vedi in MODEL SETUP in baso la riga sotto MULTI ti dice la versione.
Se il modulo è esterno lo aggiorni via usb.
Qui ti spiega tutto:
https://github.com/pascallanger/DIY-...odule/releases
Vecchio 19 dicembre 19, 22:33   #114 (permalink)  Top
Data registr.: 08-12-2004
Residenza: Udine
Buonasera,
leggendo i vari post (più o meno recenti) a parte l'ultimo problema dell'aggiornamento, mi sembra una buona radio.
La domanda però è: esiste ancora ( visto che in molti siti la danno come discontinua)?
elios non è collegato   Rispondi citando
Vecchio 19 dicembre 19, 22:57   #115 (permalink)  Top
L'avatar di rosnik
Residenza: Brescia
Originalmente inviato da elios Visualizza messaggio
Buonasera,
Scusa...sai...
il JumperTX (che è il sistema operativo per altro clone OpenTX sistema operativo);
è stato sostituito
( sempre il cliante lo voglia altrimento JumperTX funziona perfettamente quasi in tutto)
da OPENTX.
La Radio T16 Prodotta da JUMPERXYZ
è sempre in produzione e pare ci resterà a lungo.
Giunsto per chiarire!!!!!!!!!!!!!
Vecchio 21 dicembre 19, 08:57   #116 (permalink)  Top
Residenza: Condino
grazie per la risposta, poi quella sera ho trovato anche io la guida e pian piano (causa il mio inglese di livello scarso) sono riuscito.
ora ho la versione 1.3.0.47
(ho il modulo esterno originale arrivatomi con la radio)
ho usato il file multi-stm-opentx-reta-inv-v1.3.0.47
Vecchio 22 dicembre 19, 23:39   #117 (permalink)  Top
L'avatar di rosnik
Residenza: Brescia
A mio avviso dovresti usare il no inversion telemetry....
Vecchio 23 dicembre 19, 12:16   #118 (permalink)  Top
Residenza: Condino
io ho il modulo multiprotocollo esterno, quello originale arrivatomi con la radio. Non ho fatto modifiche hardware, non ho installato nessun modulo interno.
io ho usato il file
la guida di github riporta:
Choosing the right firmware file:
- Choose erskytx or opentx or ppm to match your radio
- Inverted telemetery (inv in the name) for external modules
- None inverted telemetery (noinv in the name) for internal modules
- debug or xn297dump files are for testing purposes or dumping data from unknown models, not for regular use
For example, for a Jumper JP4IN1, iRangeX IRX4, etc., and a radio running OpenTX or JumperTX you probably want the file named multi-stm-opentx-inv-[version].bin.
Vecchio 23 dicembre 19, 13:25   #119 (permalink)  Top
Residenza: Condino
update openTX 2.3.3 riuscito con successo
Sono riuscito ad aggiornare il firmware della radio a OpenTX 2.3.3 tramite Companion.
Ho seguito questa guida
https://www.youtube.com/redirect?red...Fusp%3Dsharing
prelevata in calce al video su youtube di TMac
(precedentemente non riuscivo a completare il flash probabilmente perchè non avevo scaricato e installato ImpulseRC Driver Fixer, fatto questo passaggio il flash è poi funzionato precisamente)
Vecchio 23 dicembre 19, 18:33   #120 (permalink)  Top
L'avatar di rosnik
Residenza: Brescia
io ho usato il file
Hai ragione tu!
chissà perchè pensavo al modulo interno....
Radiocomando JUMPER T16 abramo.nerva Merc. Motori ed Elettronica 0 04 luglio 19 23:40
Prime prove Asso52 Categoria F3K 12 02 aprile 17 08:21
Prime prove di ballo Clabe Categoria F3K 4 21 maggio 12 08:56
Prime prove muggio70 Elimodellismo Principianti 0 08 gennaio 07 21:12
Tutti gli orari sono GMT +2. Adesso sono le 07:57.
