Vecchio 02 aprile 12, 00:09   #1 (permalink)  Top
L'avatar di merengue
Data registr.: 27-05-2004
News FrSky
news interessanti da FrSky, fresche fresche (e no pesci ):
1, FAS-100 (FrSky Ampere Sensor-100A)
Dimension: 38*30*10mm
Weight: 24g
Measurement range: 0~100A
Current of board: 33mA
Update Rate: ≤1s
Manual_FAS-100.pdf
2, Beta test version for DHT-U new firmware with data log function.
2.1, SD card logo will show up on the main screen after it is inserted into SD reader;
2.2, Press the top left button on DHT-U to enter setting menu for data log;
2.3, Log time (time to start data log: 1/3/5 minutes after powering up) and log step (time interval: 1/2/5 seconds) are selectable;
2.4, File format for data log: txt.
DHT-U Upgrade ROM_SD.zip
3, Below products have been in work, more details will follow afterwards.
3.1, TFR8SB (FASST 2.4GHz compatible 8ch receiver with﹡S. Port and RSSI output)
3.2, D12MB (﹡S. Port & CPPM compatible servo)
3.3, SPC-01 (﹡S. Port channel changer)
3.4, RPM-BL (RPM Sensor for Brushless Motor)
3.5, V8FR-II (upgrade version of V8FR-HV, compatible with all FrSky modules of V8&D modes, improves sensitivity, receive function only)
﹡S. Port is compatible with Futaba S. Bus servos and FrSky D12MB servo.
merengue non è collegato   Rispondi citando
News IL GENERALE Automodellismo Mot. Scoppio On-Road 14 24 aprile 09 22:29
News claudioD Navimodellismo a Vela 5 28 maggio 08 13:09
news kappadj286 Automodellismo Mot. Scoppio On-Road 2 09 maggio 07 11:39
news cnemo Elimodellismo Motore Elettrico 2 26 aprile 06 14:44
Tutti gli orari sono GMT +2. Adesso sono le 03:08.
