Vecchio 05 novembre 10, 20:31   #431 (permalink)  Top
L'avatar di pragamichele
Data registr.: 11-07-2006
Residenza: Verona
Originalmente inviato da liftbag Visualizza messaggio
Però se leggi i commenti su rcgroups riguardo i file di setting dei modelli postati nella pagina di supporto, sembra siano impostazioni di base e anche malfatte. Non so se farci affidamento, anche solo per iniziare.
le tue impostazioni sembrano buone.
potresti provare a postare tu per primo il file di setting di questo modello?
e vediamo cosa succede!
sarei felice di provare a caricarlo.
pragamichele non è collegato   Rispondi citando
Vecchio 05 novembre 10, 21:14   #432 (permalink)  Top
Residenza: Verona
DX8 Un-commanded Servo Movement Service Bulletin
Recently, the Horizon Hobby Service Center has received a small number of reports from customers claiming un-commanded servo movements and loss of RF link during the activation of the vibrator motor in some DX8’s from the initial shipment.
Horizon requests that all DX8 customers with the Product ID (PID) HS008X or HS009X found in the battery compartment carefully check their radios to determine if their transmitter has this issue prior to flying.
Transmitters with a PID other than HS008X or HS009X are not affected by this bulletin.
If you have a DX8 with the affected PID, please perform the following test.
Step 1: If your model is electric, unplug motor leads from ESC for safety.
Step 2: In the function list, select Timer Screen and set a 0:10s Count Down timer to Tone/Vibe.
Step 3: With model powered on and connection established, activate timer and observe servos for un-commanded movement and receiver for loss of RF link.
Should you find that your transmitter is affected by this issue, please contact your nearest Spektrum authorized service center to arrange for a free upgrade to your DX8 performed by a Horizon Hobby authorized Technician.
Click here to complete the Spektrum DX8 Return Request form.
You may also e-mail the Horizon Hobby Product Support team. Please type "DX8 Return Request Form" in the subject line.
Please include your shipping address, daytime phone number, and PID code from your Spektrum DX8 transmitter. Click here to e-mail Product Support.
Horizon will pay for all ground shipping.
If you have further questions, please call Horizon Hobby Product Support at 877-504-0233.
Consumers outside the US and Canada should contact their local retailer or distributor. A list of International distributors may be found at: Horizon Hobby: Store Locator.
As with all RC aircraft, please check your transmitter and equipment prior to each flight.
Horizon Hobby and the Spektrum team apologize for this inconvenience.
per chi non ne fosse al corrente, meglio controllare.
se il codice corrisponde (come il mio) è meglio fare ripetute prove a terra senza motore.
alla radio verrà messo un condensatore sul vibratore e credo ritarato il modulo rf.
Vecchio 05 novembre 10, 22:23   #433 (permalink)  Top
L'avatar di liftbag
Data registr.: 10-03-2010
Originalmente inviato da pragamichele Visualizza messaggio
Si, io ho già fatto un sacco di controlli, visto che anche la mia ha il codice incriminato. Sembra a posto, ma come giustamente osservano oltreoceano, non possiamo sapere se prima o poi la vibrazione non inneschi il problema, e se sei in volo...
Alcuni per paura, disinseriscono la vibrazione, ma io la trovo oltremodo utile.
Riguardo i files di settaggio dei modelli, non so come fare l'upload a Spektrum...
P.S.
Forse ho capito che intendevi fare l'upload qui sul forum.
Stasera non posso. Ci provo domani.
liftbag non è collegato   Rispondi citando
Vecchio 05 novembre 10, 22:26   #434 (permalink)  Top
Residenza: Verona
per spektrum non saprei come fare l'upload ma teoricamente se tu estrai il file dalla scheda lo puoi passare a chi vuoi, giusto?
Vecchio 05 novembre 10, 23:23   #435 (permalink)  Top
L'avatar di liftbag
Si, credo di poterlo inserire come allegato in formato zip in qualsiasi post.
Anzi, ora ci provo
Nello zip ho inserito sia il settaggio per l'mSR, sia quello per il 120SR.
P.S.
Rispetto a quanto postato in precedenza, ho fatto due modifiche.
La prima è la curva gas normal, concepita per casa, l'ho limitata all'80%. Inoltre ho abilitato gli esponenziali sulle curve gas, che le raccorda, invece di rederle spigolose.
La seconda è il mix elev > aile, che ora è su due livelli diversi, meno efficace in stunt 1 e più marcato in stunt 2.
Ricordati che la coda è trimmata anche con la manopola aux3, quindi se non riesci a trimmarla con il trim digitale, è perché probabilmente hai la manopola tutta da un lato invece che al centro.
Files allegati
Tipo file: zip Blade_120SR-mSR_spm.zip‎ (3,6 KB, 86 visite)
Ultima modifica di liftbag : 05 novembre 10 alle ore 23:32
Vecchio 06 novembre 10, 11:16   #436 (permalink)  Top
Data registr.: 28-06-2006
Residenza: catania
scusate potreste spiegare come fare la verifica del problema su un' eli a scoppio e quali sono i sintomi? grazie!
granmaster non è collegato   Rispondi citando
Vecchio 06 novembre 10, 11:24   #437 (permalink)  Top
Residenza: Verona
Originalmente inviato da granmaster Visualizza messaggio
motore elettrico scollegato o scoppio spento,
si attiva il timer su 10 secondi con allarme vibro,
si verifica se a vibrazione inserita ci sono anomalie sui servi,
tipo vibrazioni o movimenti non voluti.
Vecchio 06 novembre 10, 12:05   #438 (permalink)  Top
L'avatar di liftbag
Controlla anche sulla seconda schermata della telemetria che non avvengano interruzioni di collegamento con le antenne (valori A e L) proprio in concomitanza con la vibrazione.
Vecchio 06 novembre 10, 16:26   #439 (permalink)  Top
Residenza: catania
grazie verifico e vi faccio sapere!
Vecchio 06 novembre 10, 19:03   #440 (permalink)  Top
L'avatar di Stealth
Data registr.: 24-10-2008
Residenza: Sondrio
sapete dove trovare la DX8 in italia/europa?
grazie.
Stealth non è collegato   Rispondi citando
ultima nata spektrum: Dx8 greg89 Radiocomandi 1 08 febbraio 10 22:48
Tutti gli orari sono GMT +1. Adesso sono le 13:10.
