17 febbraio 15, 22:41 | #1 (permalink) Top |
User | vendo Carica Batterie HYPERION 720i Super Duo net 3
vendo Carica Batterie HYPERION 720i Super Duo net 3, usato ma perfettamente funzionante. (carica 2 pacchi fino a 7s contemporaneamente!!!!) Per info e foto: info@umbe.it Euro 150 spedito Hyperion EOS 0720i SUPER DUO3 7S CHARGER. Product Description: The Super DUO is not to be confused with past models bearing the 0720 designation as they were all single-port chargers. This charger is sporting two identical output ports, each port capable of providing 500W of raw charging power. "0720" is to be interpreted as 7 Cells max - 20Amps max - per port, being a DUO charger. In order to provide all 500W per channel (1000W total), the Super DUO needs 24V-28V of input voltage but can naturally also be operated on lower input voltages (from 11V). Feature DC Input With Integrated balancers TCS & STORE MODE- DUAL 20A/500W max Outputs with max 14S SYNC MODE Hyperion's most powerful charger to date! 1000W total - 500W per port Charger delivered with HP and XH lipo adapter plates USB cable and clips. EOS 0720i SDUO3 DC INPUT 11V~28V Charge a split-pack in network mode using both ports for up to 14S at 1000W max. --------------------------- Nome: umberto Cognome: garelli Città: Montaldo Mvi (CN) |
ISTRUZIONI ITA CARICABATTERIE HYPERION EOS 720i super duo 3 | PUKAS | Elimodellismo Motore Elettrico | 18 | 24 settembre 20 14:12 |
Hyperion carica batterie EOS 720i Super Duo3 | antonio bonfa' | Merc. Motori ed Elettronica | 1 | 08 settembre 13 13:57 |
Carica batterie HYPERION EOS1420i NET 3 | Pinmax86 | Batterie e Caricabatterie | 21 | 06 febbraio 12 22:11 |
Cerco carica batt.HYPERION EOSO 720i net | birell68 | Compro | 1 | 07 agosto 11 00:06 |
