Vecchio 17 febbraio 15, 22:41   #1 (permalink)  Top
zheus
L'avatar di zheus
Data registr.: 28-08-2005
Residenza: cuneo
Invia un messaggio via MSN a zheus
vendo Carica Batterie HYPERION 720i Super Duo net 3
vendo Carica Batterie HYPERION 720i Super Duo net 3, usato ma perfettamente funzionante.
(carica 2 pacchi fino a 7s contemporaneamente!!!!)
Per info e foto: info@umbe.it
Euro 150 spedito
Hyperion EOS 0720i SUPER DUO3 7S CHARGER.
Product Description:
The Super DUO is not to be confused with past models bearing the 0720 designation as they were all single-port chargers. This charger is sporting two identical output ports, each port capable of providing 500W of raw charging power. "0720" is to be interpreted as 7 Cells max - 20Amps max - per port, being a DUO charger. In order to provide all 500W per channel (1000W total), the Super DUO needs 24V-28V of input voltage but can naturally also be operated on lower input voltages (from 11V).
Feature
DC Input
With Integrated balancers
TCS & STORE MODE- DUAL 20A/500W max Outputs with max 14S SYNC MODE
Hyperion's most powerful charger to date!
1000W total - 500W per port
Charger delivered with HP and XH lipo adapter plates
USB cable and clips.
EOS 0720i SDUO3 DC INPUT 11V~28V
Charge a split-pack in network mode using both ports for up to 14S at 1000W max.
Nome: umberto
Cognome: garelli
Città: Montaldo Mvi (CN)
[COLOR=blue][B][COLOR=blue]- PROTOS 500 - Logo 500 Vstabi - Autogiro
zheus non è collegato
