| | #1 (permalink) Top |
| User Data registr.: 18-06-2009 Residenza: Treviso
| Nuove Lipo Turnigy Bolt
Nuove Lipo Turnigy Bolt Batteries & Accessories>Turnigy BOLT ![]() Turnigy Bolt series high voltage lithium polymer batteries are here, ready to bring out the next level of power to your high performance model. Turnigy Bolt batteries are built to the absolute highest of standards to provide competition level performance. With features such as gold plated balance leads, silver plated discharge wires and a reformulated matrix to allow you to safely charge them up to 4.35 volts per cell! These batteries are simply unmatched by any other in performance and build quality! In addition to the higher nominal and max voltage, they are engineered to take high C rate discharge up to 65C continuous. Basically what this means is that these batteries will provide more power in your machine especially during high current draw maneuvers, and they will provide a longer cycle life due to the lower operating temperatures of the pack. Top notch performance and build quality make these packs ideal for high-demand flying such as 3D helicopters, EDFs, F3A and any other high current draw applications. Each pack is built with heavy duty flexible silicone wire leads and a pre-installed connector ready to handle all you can throw at it. The great thing about the Turnigy Bolt batteries is that you can charge them with any standard lipo charger for basic use, they will simply perform like a standard pack. When using the proper charger such as our Turnigy Neutron chargers, which is designed with special protocol for these LiHV batteries, you can unlock the full potential of the Turnigy Bolt batteries. More than just a fancy name. TURNIGY Bolt series lithium polymer batteries are built with a LiCo nano-technology substrate complex and an all new CNT (carbon nano tube) additive greatly improving power transfer making the oxidation/reduction reaction more efficient, this helps electrons pass more freely from anode to cathode with less internal impedance. In short; less voltage sag and a higher discharge rate than a similar density lithium polymer (non nano-tech) battery. For those that love graphs, it means a straighter, longer curve. For pilots it spells stronger throttle punches and unreal straight-up performance. Unfortunately with other big brands; numbers, ratings and graphs can be fudged. Rest assured, Turnigy Bolt series LiHV packs are the real deal, delivering unparalleled performance! Features: Higher charge voltage than standard lipos Super high 65C discharge rate Perfect for high performance models Higher capacity than comparable size packs Heavy duty silicone wire discharge leads Specs: Capacity: 5400mAh Voltage: 3S1P / 3 Cell / 11.4V Discharge: 65C Constant / 130C Burst Weight: 439.5g Dimensions: 167x28.6x49mm Balance Plug: JST-XH Discharge Plug: 5.5mm Bullet Connector Wire Gauge: 10AWG Ultima modifica di AEROX_15 : 06 agosto 14 alle ore 14:41 |
| Bookmarks |
| Strumenti discussione | |
| Visualizzazione | |
| nuove lipo turnigy.... | myzyo | Batterie e Caricabatterie | 4 | 25 giugno 10 12:17 |
