Vecchio 11 marzo 09, 18:50   #1 (permalink)  Top
Data registr.: 04-03-2009
buggy 1:8 ishima
qualcuno conosce questo buggy!!! su alcune riviste dicono che sia nuova come marca..... a guardare le foto non è male!!! ISHIMA RACING
mattialapo non è collegato   Rispondi citando
Vecchio 11 marzo 09, 19:28   #2 (permalink)  Top
Sospeso
Data registr.: 21-02-2008
Residenza: S.P.Q.L.
Immagini: 14
In pratica questo modello è stato creato dallo stesso progettista e ingegnere della PIKTOR 2 dopo averla lasciata per passare alla ISHIMA.
RAVE M1.0S
Ready To Run 1/8th scale
Nitro powered buggy
Height : 160mm
Weight : 3380g
Length : 485mm
Width : 305mm
RVB-S001.RTR
No Compromise!
Best performance 1/8th scale 4WD
“Ready To Run” racing buggy
The ISHIMA RAVE M1.0S is the entry-level version of the RAVE 1/8 buggy range.
Although we put the words “entry-level”, there is NO COMPROMISE been done. The RAVE M1.0S has the same performance in all conditions as the competition M1.0R version, only by using different production techniques we lowered the cost but not the performance.
The designers of ISHIMA RACING strove to have a strong, reliable and high performance 1/8 RTR buggy.
The result is the RAVE M1.0S with NO COMPROMISE
The overall weight of only 3380gr, the low center of gravity and the balanced load distribution provides outstanding driving dynamics and excellent track stability under any racing conditions.
The ISHIMA signature lay-down shock system and the optimized suspension geometries provides easy handling and precision controlability , no matter if you drive on flat fast tracks, bumpy technical tracks or sky-high jumps. The ISHIMA RAVE M1.0 will give you full confidence from the first moment you pull the throttle trigger...
Ball type front suspension
The ISHIMA racing design team adopted the well proven ball type front suspension to the RAVE M1.0S.
The ball type suspension system features:
  • Easy adjustment of the camber
  • Possibility to change the track (width) of the car
  • Smooth and precise steering
  • Increased suspension travel
  • Increased steering travel
  • Strong, reliable, slob free
  • Less parts count
Chassis
ISHIMA racing’s design team choose for the RAVE M1.0S a smooth countersunk CNC-machined T6 grade aluminium chassis, instead of the mould stamped alloy chassis found on almost all RTR cars on the market.
The advantages of a CNC-machined chassis are
  • Higher precision and better tolerances
  • The aluminium is not been exposed to extreme stress on the material during production (pressure during stamping of the plates)
  • Nice and clean machined edges (no rough borders)
enzocom123 non è collegato   Rispondi citando
Vecchio 11 marzo 09, 20:04   #3 (permalink)  Top
Ciao Mauro.
L'avatar di Aduken
Data registr.: 20-05-2008
Residenza: Viggiu' (VA)
Invia un messaggio via MSN a Aduken
Originalmente inviato da enzocom123 Visualizza messaggio
Se non sai le cose.....taci!!!
La PIKTOR Rush 2 e' stata progettata da (e scommetto che neanche lo sapevi) Philippe Lachat (noto pilota, che non ha affatto lasciato la Piktor)
mentre la Ishima Rave e' stata fatta dal padre Cloude Lachatt (noto pilota di altri tempi).
Tornando in topic anche io volevo prendere la Rave, solo che sono un po' svogliato e non mi sono mai interessato per quanto riguarda prezzi e ricambi ed ho lasciato perdere
Originalmente inviato da uno sbruffone
Modellisticamente sei zero
Oh povero me....tanti anni buttati via.....
Aduken non è collegato   Rispondi citando
Vecchio 11 marzo 09, 20:16   #4 (permalink)  Top
Sospeso
Residenza: S.P.Q.L.
Immagini: 14
Originalmente inviato da Aduken Visualizza messaggio
Infatti in pratica sono la stessa cosa padre e figlio piloti e progettisti
Vecchio 11 marzo 09, 20:24   #5 (permalink)  Top
Data registr.: 06-07-2008
la ishma di veramente innovativo ha solo lo sterzo su sfere, innovazione introdotta ormai su tutte le nuove auto rally che rendono lo sterzo piu veloce con ampiezza di sterzata maggiore. una figata!!!
mantuaboy non è collegato   Rispondi citando
Novita' x ISHIMA RAVE M1.0 series Aduken Automodellismo Mot. Scoppio On-Road 4 15 ottobre 08 00:20
ISHIMA RAVE M1.0R RVB-R001.K Kit version Aduken Automodellismo Mot. Scoppio On-Road 46 29 settembre 08 14:24
Ishima M1.0RR Aduken Automodellismo Mot. Scoppio On-Road 15 01 luglio 08 08:49
buggy 1/10 fv94inter Automodellismo Mot. Scoppio On-Road 32 02 aprile 08 22:13
buggy big nano Automodellismo Mot. Scoppio On-Road 8 11 giugno 06 22:03
Tutti gli orari sono GMT +2. Adesso sono le 00:37.
