| | #1 (permalink) Top |
| User Data registr.: 04-03-2009
| buggy 1:8 ishima
qualcuno conosce questo buggy!!! su alcune riviste dicono che sia nuova come marca..... a guardare le foto non è male!!! ISHIMA RACING |
| | #2 (permalink) Top |
| Sospeso |
In pratica questo modello è stato creato dallo stesso progettista e ingegnere della PIKTOR 2 dopo averla lasciata per passare alla ISHIMA. RAVE M1.0S Ready To Run 1/8th scale Nitro powered buggy Height : 160mm Weight : 3380g Length : 485mm Width : 305mm RVB-S001.RTR No Compromise! Best performance 1/8th scale 4WD Ready To Run racing buggy The ISHIMA RAVE M1.0S is the entry-level version of the RAVE 1/8 buggy range. Although we put the words entry-level, there is NO COMPROMISE been done. The RAVE M1.0S has the same performance in all conditions as the competition M1.0R version, only by using different production techniques we lowered the cost but not the performance. The designers of ISHIMA RACING strove to have a strong, reliable and high performance 1/8 RTR buggy. The result is the RAVE M1.0S with NO COMPROMISE ![]() ![]() ![]() The overall weight of only 3380gr, the low center of gravity and the balanced load distribution provides outstanding driving dynamics and excellent track stability under any racing conditions. The ISHIMA signature lay-down shock system and the optimized suspension geometries provides easy handling and precision controlability , no matter if you drive on flat fast tracks, bumpy technical tracks or sky-high jumps. The ISHIMA RAVE M1.0 will give you full confidence from the first moment you pull the throttle trigger... ![]() ![]() ![]() Ball type front suspension The ISHIMA racing design team adopted the well proven ball type front suspension to the RAVE M1.0S. The ball type suspension system features:
ChassisISHIMA racings design team choose for the RAVE M1.0S a smooth countersunk CNC-machined T6 grade aluminium chassis, instead of the mould stamped alloy chassis found on almost all RTR cars on the market. The advantages of a CNC-machined chassis are
| | #3 (permalink) Top | ||
| Ciao Mauro. | Citazione:
![]() La PIKTOR Rush 2 e' stata progettata da (e scommetto che neanche lo sapevi) Philippe Lachat (noto pilota, che non ha affatto lasciato la Piktor) mentre la Ishima Rave e' stata fatta dal padre Cloude Lachatt (noto pilota di altri tempi). Tornando in topic anche io volevo prendere la Rave, solo che sono un po' svogliato e non mi sono mai interessato per quanto riguarda prezzi e ricambi ed ho lasciato perdere
__________________ Citazione:
| | #4 (permalink) Top | |
| Sospeso | Citazione:
| Bookmarks |
| Novita' x ISHIMA RAVE M1.0 series | Aduken | Automodellismo Mot. Scoppio On-Road | 4 | 15 ottobre 08 00:20 |
| ISHIMA RAVE M1.0R RVB-R001.K Kit version | Aduken | Automodellismo Mot. Scoppio On-Road | 46 | 29 settembre 08 14:24 |
| Ishima M1.0RR | Aduken | Automodellismo Mot. Scoppio On-Road | 15 | 01 luglio 08 08:49 |
| buggy 1/10 | fv94inter | Automodellismo Mot. Scoppio On-Road | 32 | 02 aprile 08 22:13 |
| buggy | big nano | Automodellismo Mot. Scoppio On-Road | 8 | 11 giugno 06 22:03 |
