Discussione: buggy 1:8 ishima
Vecchio 11 marzo 09, 19:28   #2 (permalink)  Top
enzocom123
Sospeso
Data registr.: 21-02-2008
Residenza: S.P.Q.L.
In pratica questo modello è stato creato dallo stesso progettista e ingegnere della PIKTOR 2 dopo averla lasciata per passare alla ISHIMA.
RAVE M1.0S
Ready To Run 1/8th scale
Nitro powered buggy
Height : 160mm
Weight : 3380g
Length : 485mm
Width : 305mm
RVB-S001.RTR
No Compromise!
Best performance 1/8th scale 4WD
“Ready To Run” racing buggy
The ISHIMA RAVE M1.0S is the entry-level version of the RAVE 1/8 buggy range.
Although we put the words “entry-level”, there is NO COMPROMISE been done. The RAVE M1.0S has the same performance in all conditions as the competition M1.0R version, only by using different production techniques we lowered the cost but not the performance.
The designers of ISHIMA RACING strove to have a strong, reliable and high performance 1/8 RTR buggy.
The result is the RAVE M1.0S with NO COMPROMISE
The overall weight of only 3380gr, the low center of gravity and the balanced load distribution provides outstanding driving dynamics and excellent track stability under any racing conditions.
The ISHIMA signature lay-down shock system and the optimized suspension geometries provides easy handling and precision controlability , no matter if you drive on flat fast tracks, bumpy technical tracks or sky-high jumps. The ISHIMA RAVE M1.0 will give you full confidence from the first moment you pull the throttle trigger...
Ball type front suspension
The ISHIMA racing design team adopted the well proven ball type front suspension to the RAVE M1.0S.
The ball type suspension system features:
  • Easy adjustment of the camber
  • Possibility to change the track (width) of the car
  • Smooth and precise steering
  • Increased suspension travel
  • Increased steering travel
  • Strong, reliable, slob free
  • Less parts count
Chassis
ISHIMA racing’s design team choose for the RAVE M1.0S a smooth countersunk CNC-machined T6 grade aluminium chassis, instead of the mould stamped alloy chassis found on almost all RTR cars on the market.
The advantages of a CNC-machined chassis are
  • Higher precision and better tolerances
  • The aluminium is not been exposed to extreme stress on the material during production (pressure during stamping of the plates)
  • Nice and clean machined edges (no rough borders)
enzocom123 non è collegato   Rispondi citando
