Vecchio 16 aprile 12, 22:06   #1 (permalink)  Top
L'avatar di Robby Naish
Data registr.: 16-10-2002
Nuova Turnigy 9XR
Ciao a tutti,
ormai dovrebbe mancare molto poco all'arrivo di quets anuova Radio.
Qui ricopio alcune info abbastanza attendibili
The 9XR is designed and built completely in-house (my back pocket reminds me of this every day).
It will use the atmega chip and can be flashed with your existing customised software. In fact, it comes standard with a similar rom to one you have mentioned.
We wont be sending out eval units because we have done alot of testing in house already and its unfair to make customers wait for further evaluations.
All our CE certs are genuine from Genuine testing companies.
Unfortunately competitors like to contest those certs by retesting and making comments to undermine their legitimacy.
Just to keep the critics quiet we will be using TUV to test.
The 9XR has a pin-out in the battery compartment for easier flashing without needing to unscrew the case.
Backlight is standard
Has inbuilt and module based antenna system
Button config makes sense
Spare parts avail from the start
Switch and pot quality far better than previous version.
The 9XR will be $50.00 and targeted at the standard user that likes flying, not fiddling with his radio or looking for a shady spot to see his LCD.
I like that radio and we're working on something similar (android based) but it wont have the takeup that the 9XR does.
[Q]Would be good if you could make them already flashed with the frsky 2.4 telementry already installed
[A]We're working with them on a module for the 9XR
No sliders, darn!
I guess we've got an addition for v2 already.
By Hobbyking Admin
module based with inbuilt 2.4 antenna plus options for FASST, DSMX & long range 433mhz plus it looks & feels much nicer.
By HK Twitter
In breve ho copiato tutto quello che hanno detto gli "interni" di HK, quindi non semplici rumors (almeno spero )
Ale
Robby Naish non è collegato   Rispondi citando
Vecchio 16 aprile 12, 22:18   #2 (permalink)  Top
L'avatar di Tommhy
Data registr.: 01-08-2006
Residenza: Perugia
Invia un messaggio via MSN a Tommhy
grazie Robby anche perchè "è un lavoro sporco ma qualcuno doveva pur farlo!" ( intendo quello di aprire un thread per la nuova radio )
e soprattutto stavo pensando... ma gli sviluppatori come Romoloman, Erazz, Bertrand, Mike e gli altri... che penseranno di tutto ciò? nel senso:
1) "fantastico finalmente hanno capito che i cinesi non sanno fare FW ma lo facciamo noi, si occupassero di darci una piattaforma seria e già pronta!"
2) "anvedi sti fi** de na ******a manco hanno detto grazie che gl'avemo fatto fà i soldi! "
Per la data di uscita girovagando si "parlava" (chiacchere poco fondate") di date da giugno a fine anno...
ovviamente se avete altre info inerenti postate e citate la fonte!
buona attesa!
Tommhy non è collegato   Rispondi citando
Vecchio 16 aprile 12, 22:54   #3 (permalink)  Top
L'avatar di LONGFLYER
Data registr.: 06-09-2008
Originalmente inviato da Robby Naish Visualizza messaggio
Ciao a tutti,
No sliders, darn!
By Hobbyking Admin
By HK Twitter
Ale
Dico la mia: sento odor di flop!
Credo che alla fine HK stia realizzando un clone plus della FlySky e che perciò risulterà arrivata tardi se davvero accadrà quello che immagino stiano facendo in casa Frsky
Vedete di non morire prima così, magari, vedremo assieme come va a finire ...
"If flying were the language of man,
soaring would be its poetry."
LONGFLYER non è collegato   Rispondi citando
Vecchio 16 aprile 12, 23:13   #4 (permalink)  Top
L'avatar di Tommhy
Residenza: Perugia
Alè è arivato l'gufo!
No a parte gli scherzi effettivamente come dice LONGFLYER i sequel non vengono sempre bene, soprattutto con una "concorrenza" come Frsky che oltre ad essere economica e anche fortemente competente!
Ma restiamo a vedere... (tanto già ho deciso di montare sulla t9x la mainboard Ersky9x, quindi dubito che la nuova uscente possa competere con quella... forse per gli stick... ma stiamo provvedendo...)
Vecchio 16 aprile 12, 23:20   #5 (permalink)  Top
Originalmente inviato da LONGFLYER Visualizza messaggio
dicci di ci cosa sai,dai...... Rumors?
Cmq credo che HK la radio se la faccia fare da Frsky su sue specifiche, non credo se la facciano realmente a casa
Vecchio 16 aprile 12, 23:33   #6 (permalink)  Top
L'avatar di merengue
Data registr.: 27-05-2004
di certo se costerà 50$, non sarà di sicuro un flop, anzi...
ricordiamoci che la 9x è stata un successo commerciale anche prima delle fw modificate, con il suo fw originale tremendo.
Se sono furbi, e sapranno dire "grazie" (ci sono 1000 modi per farlo) alla comunità di sviluppatori, non potrà che essere un super successo
Vecchio 16 aprile 12, 23:42   #7 (permalink)  Top
Smile
Originalmente inviato da merengue Visualizza messaggio
Dai Merengue, non siamo all'anno zero e coprarla a 50$ per poi aggironarla con Frsky magari, con due conti, parrà ovvia la convenienza verso una ipotetica Frsky di ben altre caratteristiche anche costasse tre volte tanto ma con modulo ed rx già compresi.
Flop inteso nel senso che potrebbe non venderne quante se ne è prospettata di fare e, riguardo le comunità software, non ci metterei la mano sul fuoco che queste poi non si spostino esclusivamente su chi gli darà maggior man forte ed in questo FrSky ne ha davvero per tutti ...
Poi, come dire: chi vivrà vedrà!
Vecchio 16 aprile 12, 23:48   #8 (permalink)  Top
Smile
Che ad HK gliela costruisca Frsky ... boh, mi pare difficile anche se tutto è davvero possibile!
Riguardo Frsky quel che so sono solo rumors ma 2+2 sappiamo tutti quanto fa ed oggi, se vuoi campare, è bene che costruisci una Tua radio giacchè tutte le nuove non hanno più modulo intercambiabile e non si può vivere solo di rx clone. Aggiungi poi una sapiente capacità di produzione e voglia di fare, nonchè apertura vera verso le comunità open-source ed il SE lascia il posto solo al QUANDO ...
Vecchio 16 aprile 12, 23:49   #9 (permalink)  Top
Moderatore
L'avatar di klamath
Data registr.: 20-09-2005
Residenza: ɐuƃoloq
Invia un messaggio via ICQ a klamath
dite quello che volete ma queste radio valgono niente di più di quello che costano! Certo la potenzialità di un software opensources su una radio è impagabile, ma per tutto il resto vale quello che costa.
Il nuovo forum riservato ai Multirotori è ONLINE...
>>> https://www.dronerc.it/forum/ <<<
Pack suoni completo con varie voci e per tutte le versioni di opentx.
https://github.com/klamath1977/opentx-HQ-italian-vp
klamath non è collegato   Rispondi citando
Vecchio 16 aprile 12, 23:55   #10 (permalink)  Top
Originalmente inviato da klamath Visualizza messaggio
dite quello che volete ma la Turnigy e tutti i surrogati valgono niente di più di quello che costano! Certo la potenzialità di un software opensources su una radio è impagabile, ma per tutto il resto vale quello che costa.
Fino ad ora ... ma Frsky potrebbe voler ribaltare questa equazione e poco male se alla fine costerà come una entry level se poi avrà potenzialità da medio-alta
Collegare Turnigy 2650mAh a Turnigy 9X FabioPE Batterie e Caricabatterie 16 25 gennaio 13 16:22
Adattatore per caricare Turnigy 2650mAh Tx Pack con Turnigy Accucel-6 FabioPE Batterie e Caricabatterie 19 04 febbraio 12 11:56
turnigy posee93 Compro 0 04 dicembre 11 16:16
Tutti gli orari sono GMT +1. Adesso sono le 20:24.
