Vecchio 25 agosto 15, 16:29   #1 (permalink)  Top
Data registr.: 18-08-2015
Turnigy 9xPro e modulo tx
Ciao a tutti,
ho appena comprato una Turnigy 9XPro e ricevente 9x8c-v2, con molta delusione appena arrivata a casa ho scoperto che la radio era senza il modulo, ora però non riesco a trovare un modulo che sia compatibile con la 9x8c e con la radio. Che modulo devo comprare?
ets23 non è collegato   Rispondi citando
Vecchio 25 agosto 15, 16:34   #2 (permalink)  Top
Moderatore
L'avatar di klamath
Data registr.: 20-09-2005
Residenza: ɐuƃoloq
Invia un messaggio via ICQ a klamath
scusa ma la 9xr pro viene venduta esclusivamente priva d modulo!
ma leggere le caratteristiche prima di compare fa tanto male???
9XR Pro Added Features:
• ARM version of er9x radio firmware with EESKYPE simulater GUI support
• 24 channel support
• 48 free mixes
• Expo, Triple rates, Curves settings
• Voice alerts
• Telemetry display
• Atmel SAM3S ARM Cortex M3 , 32 bit Micro-controller , 512K flash , 64Kb of SRAM
• 4Mb EEprom for 30+ model storage
• Micro SD card (Included)
• Mini USB port, for access to SD card files and radio programing
• 1/2 Watt Audio Amplifier with digital control.
• RS232 Serial Port for External telemetry connection through Futaba trainer jack. (for DHT ,DXT)
• Logic level Serial Port for external Blue Tooth modules (HC-06,RN42)
• Dimable LED Back light
• Haptic Buzzer (pager vibrator) for trim center alert and alarm notifications
• Real "Tact" switches on menu keys, give positive feedback indication
• Built in bootloader. (Firmware can be updated in less than 15 seconds!)
• Full built-in Telemetry support for the latest RF modules. New DSM modules coming soon.
• Speaker and headphone outputs
• Ball Bearing gimbals
• Digital Trims
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate, Sub trims, travel adjust and Exponential
• Supports Heli/Aero/Glider and custom Model Types
• Programming templates based on model type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• JR Form Factor RF Modules (ORX Dsm2, ORX Open LRS 433Mhz etc)
• Programmable warnings
• 1.5Amp, 5V main switching regulator, with wide input voltage (6.5 - 30V) (uses 3S lipo connection same as 9XR)
• Rotary encoder with push switch port (rotary encoder not included - user upgrade)
• Support for 6-way switch and more 3 way switches. (User upgrade)
• And so much more!!
A full set of user manuals and user videos are available to help learn how to use this powerful radio. Online support and user forums available at: Turnigy® 9XR Transmitter
Spec:
Channnel: Up to 24 supported
Display: 128*64LCD (dimmable Backlit)
Support Type: Heli/Acro/Glid/Custom
Model Memory: 30+
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer/Speaker: Yes
Battery Compartment: 112 x 44 x 27mm
Weight (less battery & Rf Module): 723g
Required:
3S Lipo Battery
RF Module
Included:
Turnigy 9XR PRO Transmitter (Mode 2 – Throttle on Left Stick)
Quick Start guide
*Note: This version is supplied without an RF Module, please order the relevant RF module from the accessories list below.
**Note: To use the telemetry with FrSky modules the optional plug in cable is required.
comunque va bene qualsiasi modulo compatibile JR
Il nuovo forum riservato ai Multirotori è ONLINE...
>>> https://www.dronerc.it/forum/ <<<
Pack suoni completo con varie voci e per tutte le versioni di opentx.
https://github.com/klamath1977/opentx-HQ-italian-vp
klamath non è collegato   Rispondi citando
Vecchio 25 agosto 15, 17:07   #3 (permalink)  Top
hai ragione è che ho ordinato un bel pò di cose e non ci ho fatto caso, l'ho sostituita di fretta alla 9X che non era disponibile da un pò e ho fatto il danno
Ma ad esempio la DSSS è compatibile con la ricevente 9X8c? quello che mi preoccupa è la compatibilità con la ricevente piu che con la radio, per la radio ho visto che ce ne sono un pò a disposizione
Vecchio 25 agosto 15, 17:14   #4 (permalink)  Top
Moderatore
L'avatar di klamath
Residenza: ɐuƃoloq
Originalmente inviato da ets23 Visualizza messaggio
il dsss se non sbaglio non è di libero uso in italia, credo si possa utilizzare solo in certi spazi, comunque il modulo dipende molto anche da cosa devi pilotare... e
s: per i bnf eflite/parkzone o che comunque utilizzano il dsm2/dsmx ti consiglio il modulo orange che tra l'altro nelle sue ultime versioni supporta anche il protocollo walkera che pero è dsss...
altrimenti se intendi avere la telemetria ti consiglio il modulo xjt frsky, al limite il djt
Vecchio 25 agosto 15, 17:17   #5 (permalink)  Top
ma l'xjt frsky è compatibile con la ricevente turnigy 9x? Per ora la telemetria non mi interessa, sto costruendo il mio primo modello e vorrei partire senza troppa carne al fuoco, in futuro potrei comprarmi la ricevente che supporta la telemetria.
Vecchio 25 agosto 15, 17:20   #6 (permalink)  Top
Moderatore
L'avatar di klamath
Residenza: ɐuƃoloq
certo che no!
le riceventi che dici tu della 9x sono flysky rimarchiate e utilizzano il protocollo AFHDS per quelle ti serve il modulo della 9x o il modulo flysky
Rc quadcopter flysky vola cielo fs 2.4g modulo trasmettitore aggiornamento + antenna per rc telecomando trasmettitore 9ch spedizione gratuita in Free Shipping 2.4G 9ch system Flysky FS rc radio Transmitter & Receiver Combo 9ch remtoe control FS-TH9X
Vecchio 26 agosto 15, 10:29   #7 (permalink)  Top
Eccolo.. Io lo cercavo turnigy e non lo trovavo.. Grazie!
compro radiocomando Turnigy 9x o similari (FlySky/iMax/Turnigy/Eurgle) niccoleo Compro 0 25 marzo 15 14:11
TX Turnigy 9X + RX Turnigy 9x8cv2 8CH full range + n°2 RX HK 6Ch V2 + Life 9.9 V 1.5 giventofly Merc. Motori ed Elettronica 2 12 marzo 15 19:49
Compatibilità turnigy 5000 mah 3S 25 C con motore turnigy mach 4 Alexlaso Automodellismo Mot. Elettrico Off-Road 1 25 dicembre 14 16:24
Nuove Turnigy Bolt e Turnigy Nanotech Ultimate su Hobbyking darksky Automodellismo Mot. Elettrico Off-Road 69 11 settembre 14 20:10
Adattatore per caricare Turnigy 2650mAh Tx Pack con Turnigy Accucel-6 FabioPE Batterie e Caricabatterie 19 04 febbraio 12 11:56
Tutti gli orari sono GMT +1. Adesso sono le 11:49.
