Vecchio 03 dicembre 14, 13:33   #641 (permalink)  Top
L'avatar di egicar
Data registr.: 08-04-2007
Residenza: Nuvolera (BS)
Originalmente inviato da chrigui Visualizza messaggio
Version 1.06
Changes since 2014-April-18
New Features & Improvements
• Added AS3X Gain monitor functions for use with AR636, AR6335, and similar
AS3X receivers. When you enable telemetry option AS3X, you are able to see
gain status in real time, and adjust it with a trimmer. Note that this function
performs the following re-configurations in your radio:
o The F-Mode switch has its outputs set to the proper values for AS3X
operation. If you are using it for other purposes, you will need to
reconfigure those features to allow AS3X to use them.
o Mix 16 (DX10t and higher) is used to control AS3X gain.
o The selected channel is reconfigured for proper control. If you change the
channel, you will need to manually re-assign the old channel to its desired
purpose.
o Enables a screen “AS3X Gains” on the Function List to configure
parameters.
o Enables the AS3X telemetry gain monitor on the telemetry screens.
o If you are using a DX6, you can tweak the gains using the roller while on
the AS3X Gains configuration screen. If you are using a higher radio, you
can adjust at any time using the desired trimmer.
Corrections
• In Heli mode, Governor Trim function now works properly.
• Fixed Servo Travel problem for second Elevator in a 4-Servo swash heli.
• Improved translations in multiple languages
• When using a trimmer in 2- or 3-position mode, trimmers were acting as Flight
Mode trims. They are now operating in Common Mode
• Trim decrement tone was being controlled by the Switch Sounds setting
• Governor Trim on Heli Trim Setup screen is now properly adjustable
• If a radio is configured as a Wireless Trainer Master, if it were used as a wired
slave it would not function. This has been corrected.
Audio System Changes
• No changes
E' lo stesso changelog della 1.06.02, perché nella 1.06.05 (successiva alla 1.06.02) non ci sono stati cambiamenti per l'utilizzatore.
Vecchio 03 dicembre 14, 13:49   #642 (permalink)  Top
L'avatar di chrigui
Data registr.: 21-07-2006
infatti...anche se il tipo a volte dice quello che gli pare
Vecchio 04 dicembre 14, 21:52   #643 (permalink)  Top
Data registr.: 11-06-2012
Residenza: Pavia
scusate dove trovo firmware per aggiornare?
Ciojkas non è collegato   Rispondi citando
Vecchio 04 dicembre 14, 23:30   #644 (permalink)  Top
L'avatar di double68
Data registr.: 27-05-2009
Residenza: Piacenza
Quindi,secondo te Egidio conviene farlo questo aggiornamento oppure aspettiamo?
La mia radio va molto bene, non vorrei ...
Inviato dal mio Sinclair ZX81
Vecchio 05 dicembre 14, 00:30   #645 (permalink)  Top
L'avatar di dex1
Data registr.: 19-01-2005
Residenza: 33170 e dintorni
Quando non dicono quale e il minimo cambiamento ,mi girano le ball.
Se ce una differenza tra 1.06.02 al1.06.05 devono dirlo.
Non vorrei che fosse appunto un aggiornamento al modulo TX.
Brutta esperienza sulla dx8.
Io per ora non aggiorno.
Vecchio 05 dicembre 14, 06:26   #646 (permalink)  Top
L'avatar di RobEly
Data registr.: 07-09-2013
Residenza: Cerreto D' Esi
Cioè? La famosa storia della riduzione di potenza????
Inviato dal mio GT-I9100P utilizzando Tapatalk
RobEly non è collegato   Rispondi citando
Vecchio 05 dicembre 14, 06:29   #647 (permalink)  Top
L'avatar di blurex
Data registr.: 25-05-2010
Residenza: cosenza
avviso
Originalmente inviato da Ciojkas Visualizza messaggio
a me arriva un mail di avviso quando è disponibile un nuovo firmware.
Alea iacta est
--trex450pro-trex500cf-trex550flybar-trex600nitro- clone trex600esp--
blurex non è collegato   Rispondi citando
Vecchio 05 dicembre 14, 09:13   #648 (permalink)  Top
L'avatar di egicar
Devi registrarti e registrare la radio su Spektrum Community e là troverai l'ultima versione di AirWare.
Egidio
Vecchio 05 dicembre 14, 09:14   #649 (permalink)  Top
L'avatar di egicar
Nuova Spektrum DX9
Da quello che ha scritto Andy Kunz, si può tranquillamente aspettare il prossimo AirWare.
Vecchio 05 dicembre 14, 13:57   #650 (permalink)  Top
L'avatar di FPVxfun
Data registr.: 08-10-2014
Residenza: Verona
Originalmente inviato da RobEly Visualizza messaggio
Infatti, non vorrei fosse quello. Diversamente il nuovo firmware è uscito per risolvere un baco (visto che non aggiunge funzionalità).
Certo che se fossi il sig. Spektrum e volessi convincere i miei utilizzatori ad aggiornare il software dotato di riduzione potenza (ovvero contro la volontà di tutti), cercherei una soluzione tipo la classica "inc.... all'italiana", ovvero farei molta pubblicità dicendo che sono uscite numerose utilissime funzionalità e sotto sotto (in piccolo e "sottovoce") ti metterei anche la riduzione di potenza.
P.S. grazie egicar x le info
FPVxfun non è collegato   Rispondi citando
JR 9303 - dx9 non compratele e se ce l'avete leggete Ingo Radiocomandi 0 29 marzo 12 20:40
retroilluminare la dx9 jr Baltimora44 Radiocomandi 2 27 marzo 12 21:35
opinioni su JR propo dx9 2.4ghz cosmic Radiocomandi 2 11 agosto 10 22:09
Tutti gli orari sono GMT +2. Adesso sono le 12:21.
