Vecchio 29 maggio 14, 15:12   #511 (permalink)  Top
L'avatar di egicar
Data registr.: 08-04-2007
Residenza: Nuvolera (BS)
Immagini: 1
Originalmente inviato da chetto1965 Visualizza messaggio
L'ultima versione è la 1.05 che trovi su Spektrum Community.
Andrea
Esatto! Non capivo il senso della domanda
"Quanto più ci innalziamo, tanto più piccoli sembriamo a quelli che non possono volare" (F. N.)
egicar non è collegato   Rispondi citando
Vecchio 29 maggio 14, 17:51   #512 (permalink)  Top
L'avatar di vs0587
Data registr.: 08-12-2009
Residenza: Saronno
Adesso è uscita la versione 1.06 del 27/05/2014!!
Version 1.06
Changes since 2014-April-18
New Features & Improvements
• Added AS3X Gain monitor functions for use with AR636, AR6335, and similar
AS3X receivers. When you enable telemetry option AS3X, you are able to see
gain status in real time, and adjust it with a trimmer. Note that this function
performs the following re-configurations in your radio:
o The F-Mode switch has its outputs set to the proper values for AS3X
operation. If you are using it for other purposes, you will need to
reconfigure those features to allow AS3X to use them.
o Mix 16 (DX10t and higher) is used to control AS3X gain.
o The selected channel is reconfigured for proper control. If you change the
channel, you will need to manually re-assign the old channel to its desired
purpose.
o Enables a screen “AS3X Gains” on the Function List to configure
parameters.
o Enables the AS3X telemetry gain monitor on the telemetry screens.
o If you are using a DX6, you can tweak the gains using the roller while on
the AS3X Gains configuration screen. If you are using a higher radio, you
can adjust at any time using the desired trimmer.
Corrections
• In Heli mode, Governor Trim function now works properly.
• Fixed Servo Travel problem for second Elevator in a 4-Servo swash heli.
• Improved translations in multiple languages
• When using a trimmer in 2- or 3-position mode, trimmers were acting as Flight
Mode trims. They are now operating in Common Mode
• Trim decrement tone was being controlled by the Switch Sounds setting
• Governor Trim on Heli Trim Setup screen is now properly adjustable
• If a radio is configured as a Wireless Trainer Master, if it were used as a wired
slave it would not function. This has been corrected.
Audio System Changes
• No changes
Stefano Spektrum DX9
vs0587 non è collegato   Rispondi citando
Vecchio 30 maggio 14, 13:04   #513 (permalink)  Top
L'avatar di chetto1965
Data registr.: 20-09-2004
Originalmente inviato da egicar Visualizza messaggio
Infatti non l'ho capito nemmeno io...
Iscritto al gruppo "Volare su Tetti" di Rivoli (TO)
chetto1965 non è collegato   Rispondi citando
Vecchio 31 maggio 14, 07:26   #514 (permalink)  Top
L'avatar di RobEly
Data registr.: 07-09-2013
Residenza: Cerreto D' Esi
Io ho fatto l'aggiornamento al' 1.06, rispetto a tutti gli altri aggiornamenti ci ha impiegato pochissimo tempo..... anche a voi è successo lo stesso?
Inviato dal mio GT-I9100P utilizzando Tapatalk
RobEly non è collegato   Rispondi citando
Vecchio 02 giugno 14, 01:05   #515 (permalink)  Top
L'avatar di double68
Data registr.: 27-05-2009
Residenza: Piacenza
Originalmente inviato da RobEly Visualizza messaggio
Devo ancora provvedere, poi ti faccio sapere.
Inviato dal mio Sinclair ZX81
double68 non è collegato   Rispondi citando
Vecchio 02 giugno 14, 01:35   #516 (permalink)  Top
Data registr.: 18-02-2012
Originalmente inviato da veleno23 Visualizza messaggio
Qualcuno potrebbe confermarmi se l'ultima versione di AirWave è la 1.05.05 e voce VOX 15092F86? Grazie
Non ce molto da capire... ho chiesto se le versioni AirWave e voce che ho riportato erano le ultime....
Le ho scritte come vengono riportate dalla rado
veleno23 non è collegato   Rispondi citando
Vecchio 02 giugno 14, 13:14   #517 (permalink)  Top
Stavolta si aggiorna solo la versione AirWave alla nuova 1.06.04 e niente aggiornamenti voce giusto?
Vecchio 02 giugno 14, 14:28   #518 (permalink)  Top
L'avatar di RobEly
Si giusto.....
Ma? L'aggiornamento al 1.06 è come una sveltina....!
Vecchio 02 giugno 14, 14:49   #519 (permalink)  Top
L'avatar di Multijet 360
Data registr.: 04-02-2011
Residenza: Taranto
Tradotto in italiano, cosa si aggiorna con la 1.06?
Spektrum DX8 Blade 350QX2
Multijet 360 non è collegato   Rispondi citando
Vecchio 04 giugno 14, 22:06   #520 (permalink)  Top
L'avatar di s_maggi
Data registr.: 14-02-2011
Residenza: Porlezza (CO)
Immagini: 50
Ciao,
Devo aggiornare la radio che ho comprato oggi,solo che ci sono due aggiornamenti, ma li devo fare tutti e due o posso solo fare l'ultimo?
s_maggi non è collegato   Rispondi citando
JR 9303 - dx9 non compratele e se ce l'avete leggete Ingo Radiocomandi 0 29 marzo 12 21:40
retroilluminare la dx9 jr Baltimora44 Radiocomandi 2 27 marzo 12 22:35
opinioni su JR propo dx9 2.4ghz cosmic Radiocomandi 2 11 agosto 10 23:09
Tutti gli orari sono GMT +2. Adesso sono le 08:21.
