Vecchio 26 aprile 12, 11:06   #1 (permalink)  Top
L'avatar di Robby Naish
Data registr.: 16-10-2002
[Tutorial] - Trasformazione Futaba a 2.4GHz.
Ciao ragazzi,
un gentilissimo ragazzo Austriaco, conosciuto su un forum mi ha preparato una esaurientissima guida per modificare la mia Fx18 e trasformarla 2.4Ghz
Quindi lo ringrazio pubblicamente, si chiama Gregor Nebel
Here is a short documentation of what I’ve did to “upgrade” my FX18 to 2.4GHz.
Used parts:
FrSky V8HT 2.4Ghz DIY Module:
Any Duo-LED for indicating which mode you use (optional):
Any ON/ON or ON/OFF/ON switch:
I used only ON/ON as there is no need for me to turn off the transmission (might be useful for a RC Simulator):
Modification:
The following pictures should give an idea of what I’ve did:
On those two pictures you can see the switch to toggle between 35MHz (green) and 2.4GHz (red).
The small button and LED in the middle (within the FX-18 logo) is the bind/indication module (also called extend board). I only drilled two holes and fixed the module by using hot glue.
The DIY module is just fixed on the center PCB, therefor use a zip tie or something simular.
On the next picture you can see the PPM signal wire (in my case yellow, but please refer to the FrSky manual for that). You need to solder this cable to the PPM pin on the FX-18 PCB. I’ve secured this wire additionally with hot glue.
To have a better view where to solder the PPM signal here is another picture (thenext picsare taken from another modification guide).
The next thing would be to battery power supply line (red circle).
Robby Naish non è collegato   Rispondi citando
Trasformazione Tx in 2,4GHz??? Nobody Radiocomandi 6 17 aprile 09 20:29
Mini Titan Tutorial + Futaba dallatorretdu Elimodellismo Motore Elettrico 30 18 luglio 08 10:06
tutorial futaba FF9 Emidio Radiocomandi 0 11 settembre 07 23:51
Tutti gli orari sono GMT +1. Adesso sono le 12:12.
