Torna indietro   BaroneRosso.it - Forum Modellismo > Categoria Elimodellismo > Elimodellismo Elettronica > Elimodellismo Sistemi Flybarless e Telemetria
Vecchio 29 luglio 20, 21:06   #1 (permalink)  Top
L'avatar di m.rik
Data registr.: 28-06-2005
Residenza: Milano
Rilasciate nuove versioni Brain 3.3.030 Firmware & applicazioni Windows, Android, iOS
As usual new Software and new Firmware notifications will be automatic, and system will prompt user of the presence of new updates once powered unit is connected to a Windows PC or Android devices or iOS devices with Internet connection active.
For those with Brain2/iKon2 that do not frequently use the APP/Software (because the controller is fine as it was set up), let's take a look at what is coming with this update:
- Software 3.3.030, Firmware 3.3.030 (45°) 29 July 2020
• Added the ability to log FrSky RSSI reading from S.Bus channel n°16 (RSSI is always measured from channel 16, the receiver, if it is a model able to send RSSI, must be set to send RSSI value pushing bind button for 5 seconds. With this mode channel 16 cannot be used as a normal channel)
• Increased the MAX value of “Rx Frame Rate uS” to 1000 also if it is not graphically visible to be able to intercept the cause of a Throttle Fail Safe
• Solved Fades calculation problem with SRXLv2 RX when one or two DSMX sat are added (this problem did not affect the reception of radio channels or telemetry but only the calculation of the receiver's Fades)
• In Advanced, if Fast Tail Servo are selected for Swashplate servo 0,1,2,3 now correct values for maximum Throw are activated (for Tail Servo 4, as before, half maximum throw are selected to avoid binding)
• Added in “Servo Chart Tail” Align DS825M servo
• In the graphs of the DIAGNOSTIC section, make small corrections of the vertical scales of the input and output signals of Elevator and Ailerons
• New version of README_for_ESC_datas_log_and_telemetry.pdf document
• Revised French instructions
• Revised some names, titles, labels, units, instructions (English and Italian)
• Improvements/optimization/compression/size reduction/speed up of the code
Android / iOS app’s:
All the new functions and improvements already listed for this "Software & "Firmware” release, plus:
• Advanced -> Rescue: added slider for “Maximum Angle”
As usual for the Android and especially iOS app publication is needed some more time not dependent from us but from Google and especially Apple.
Enjoy!
www.msh-electronics.com
m.rik non è collegato   Rispondi citando
Modalità elencata Modalità elencata
Rilasciate nuove versioni Brain 3.3.027 Firmware & applicazioni Windows, Android, iOS m.rik Elimodellismo Sistemi Flybarless e Telemetria 1 08 luglio 20 10:29
Nuove applicazioni per la penna 3D Eagle366 Modellismo 5 17 marzo 20 20:27
Hobbyking IOS & Android 4CH WiFi Receiver RC Fabiuz Aeromodellismo Volo Elettrico 8 11 maggio 12 15:13
Tutti gli orari sono GMT +2. Adesso sono le 00:17.
