Torna indietro   BaroneRosso.it - Forum Modellismo > Categoria Automodellismo e Motomodellismo > Automodellismo scalers/crawlers
Vecchio 20 febbraio 08, 02:15   #1 (permalink)  Top
L'avatar di under
Data registr.: 29-01-2008
Residenza: Milano
Talking AX10 SCORPION RTR - Rock Racer/Rock Crawler / Quando e senza senso!
Ecco la nuova uscita della AxialRacing!
link->Axial Racing - Press : AX90002 AX10 Scorpion RTR Rock Racer
AX10 SCORPION ROCK RACER (RTR)
Purpose built for the Rocks! Going Places Where Others Can't.
Based upon the very popular competition ready AX10 Kit, the AX10 Scorpion is a Ready-to-Run with 2 configurations!
• Rock Crawler: Takin' it slow - swap out the 20t pinion to the 14pt pinion and install the front locker (parts included). The Rear locker is already installed. This will give you true crawling performance.
• Rock Racer: Attack the rocks at full speed out of the box.
Features
• Complete ready to race/crawl out of the box
• 4WD
• 27T Electric Motor: Tear up the terrain in-door or out-doors. Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go!
• 20T pinion paired with an 87T spur gear gives you a quick rock racer ratio, or install the included 14T pinion for a slower rock crawling ratio.
• True Beadlocks: No Messy Glue!
• Hi-quality Composite Plastic and Metals
• Durable (ESC) Electronic Speed Controller: Hi-quality durable forward and reverse speed controller.
• Hi-Torque Servo help hold your line when rock crawling
• Solid Rear Axle lockouts improve ground clearance when crawling
• Slipper Clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain.
• Aluminum Chassis plates with a molded nylon skid plate provide a solid and rigid chassis
• Ultra compact and lightweight transmission
• Open front diff for smaller turning radius, or install the included front locker for more traction when rock climbing!
• Rear axle is locked for better traction.
• Full Ball bearings
• Overall gear ratio range from 15:1 to 74:1
• Transmission: 2.6:1; center mounted
• Differentials: Front - gear differential; Rear - locked (spool)
• Transmission: Single-speed
• Tires: Axial 2.2 Rock Lizards
• Wheels: Axial 2.2 8 Hole Beadlocks (Satin Chrome)
• Suspension: 3 Link
• Drive Shafts: Universal front and rear
Chassis
Wheelbase: 304mm~320mm (12”~12.6”)
Width: 254mm (10”)
Height: 156mm (6.125”)
Weight: 1588g (3.5 lbs)
Articulation: 70°
Ground Clearance: 79mm (3.125”)
Body
Length: 450mm (17.75”)
Width: 190mm (7.50”)
Height: 125mm (5.00”)
Electronics
Radio: 2 Channel
Servos: 1 Hi-Torque (Standard Size)
Forward/Revers ESC
Motor: 27T 540/550 Size
Required Items
(1) 7.2v Stick Pack Battery
(8) AA size Batteries
2 configurazioni Race e Crawler!
Costo-> $475.00 / Euro 322,5587
Ke dire!
LO VOGLIO!
Voi ke ne pensate!
DA quando ho un monster truck (Mad Truck HL) Voglio provare anke le brezza del crawler!
under non è collegato   Rispondi citando
Vecchio 21 febbraio 08, 13:31   #2 (permalink)  Top
Data registr.: 11-12-2006
Ahhhh!!! Ti prego!! Ridimensiona l'immagine (basta un 800x600)!!
Comunque splendido!!
Mister D non è collegato   Rispondi citando
Vecchio 21 febbraio 08, 13:37   #3 (permalink)  Top
L'avatar di under
Residenza: Milano
SORRY!!
L'IMMAGINE ARRIVA DIRETTA DAL SITO AXIAL!
LO TROVATO IN UN SITO AMERICANO A 196 EURO CON LA SPEDIZIONE!
FACCIO LA PAZZIA!
E TROPPO BELLO E POI VOLGIO UN CRAWLER !
Vecchio 21 febbraio 08, 19:06   #4 (permalink)  Top
L'avatar di bubbax
Data registr.: 04-07-2006
Originalmente inviato da under Visualizza messaggio
SORRY!!
FACCIO LA PAZZIA!
ciao, l'hai comprato l'Axial? Mi mandi cortesemente il link del sito a:
marinata2002@libero.it
grazie
bubbax
bubbax non è collegato   Rispondi citando
Vecchio 22 febbraio 08, 03:16   #5 (permalink)  Top
L'avatar di under
Residenza: Milano
non lo ancora preso ma mi sa che tra poco me lo prendo appena mi prendo bene l sito dove prenderlo e questo!
Axial's New RTR Scorpion Crawler
Vecchio 22 febbraio 08, 16:20   #6 (permalink)  Top
Data registr.: 21-02-2008
ma su questo sito ce ne sono due....
AXI90001 Axial Ax10 Scorpion 10Th Scale Rock Crawler
quale è meglio ?
carlo_it non è collegato   Rispondi citando
Vecchio 23 febbraio 08, 03:33   #7 (permalink)  Top
L'avatar di under
Residenza: Milano
questo!
Vecchio 23 febbraio 08, 12:35   #8 (permalink)  Top
xche ?
a me sembra piu' giocattolo.
Vecchio 23 febbraio 08, 13:13   #9 (permalink)  Top
L'avatar di under
Residenza: Milano
allora ti spiego e lo stesso mezzo solo ke quello con la scocca di betty boop e da montare e invece altro e gi montato e a gia nella scatola il kit di conversione crawler / racer.
quindi se ti piace montate tic onsiglio qeuto e poi ci predi dal sito la modifica per farlo diventare un racer/crawler
altrimenti prendi RTR che e tutto pronto!
tutto ok!
allora io ti consiglio di prendere RTR che ha gia tutto dentro e un bel motore potente!
Vecchio 23 febbraio 08, 20:39   #10 (permalink)  Top
ciao scusate se mi intrometto, ma il motore non è che sia sto gran che potente, io ti consiglierei un bel 55 spire
tltkrawler non è collegato   Rispondi citando
Rock Crawler nonno Automodellismo Mot. Elettrico Off-Road 1 11 febbraio 08 21:50
TLT 1 rock buster vs mini LST 2 ? maxastuto Automodellismo Mot. Elettrico On-Road 3 19 novembre 07 18:30
Let's Rock... Benedetta Elimodellismo in Generale 11 23 agosto 05 22:31
Tutti gli orari sono GMT +1. Adesso sono le 22:12.
