Vecchio 15 aprile 11, 11:52   #1 (permalink)  Top
Data registr.: 29-07-2010
Che motore è?
Salve a tutti ho comprato questo motore
volevo sapere se qualcuno di voi sa che modello è, volevo restaurarlo e metterlo in funzione , è il primo di questo tipo che compro con accensione a candela e volevo sapere come devo fare per metterlo in moto cioè cosa mi serve? serve una bobina? come la devo collegare(schema).
grazie mille a tutti in anticipo!!!!
fusion87 non è collegato   Rispondi citando
Vecchio 15 aprile 11, 12:14   #2 (permalink)  Top
L'avatar di fradellaq
Data registr.: 31-05-2009
Residenza: Benevento
La vedo dura, comunque in bocca al lupo.
fradellaq non è collegato   Rispondi citando
Vecchio 15 aprile 11, 14:51   #3 (permalink)  Top
Data registr.: 13-01-2010
Residenza: ------
Smile O&R Engine
Questo è quello che ho trovato googlando:
Ohlsson and Rice company formed
"By 1941 Irv Ohlsson had teamed up with Harry Rice, and the firm of Ohlsson & Rice were producing a “.19”, a “.23” and a “.60” that were highly popular. No other engines at the time combined the reliability, ease of maintenance, simplicity of operation and unlimited life of the O & R engines. The Second World War put a temporary hold on their success, however, as all manufacturing facilities were turned over to military production. By the time the war shut down their production, they had produced about 75,000 engines.
As soon as the war was over, O & R got back into production. Even with a shortage of needed materials and machines somewhat worn out by 3-shift a day wartime production use, they jumped back into a market that had a seemingly endless demand for their products. Modelers were hungry to get back into flying, and O & R took advantage of the market by buying the machinery needed to meet the huge demand. By the end of 1947 their production had risen to almost a thousand engines per working day."
Link:
Model Engine Builders—Irwin Ohlsson
Max
http://www.gaapallini.it/
max_c26acro non è collegato   Rispondi citando
Vecchio 15 aprile 11, 14:57   #4 (permalink)  Top
L'avatar di dooling
Data registr.: 22-08-2007
Residenza: Portofino - Rapallo
Originalmente inviato da fusion87 Visualizza messaggio
Ciao, la scheda lo presenta (con il ?) come ohlsson&rice, a me non sembra perchè O&R erano fatti così .
Con il carburatore anteriore (a meno che non si tratti di quache versione particolare).
Nello stato in cui si trova, temo che sarà abbastanza complicato rimetterlo in funzione, bisogna innanzitutto vedere se all'interno è in "ordine" , poi mancano i pezzi che puoi vedere nella foto allegata.
Servono le "puntine", la candela, la bobina ed il condensatore.
In tutta sincerità, credo che ti convenga ripulirlo per bene e metterlo "sotto vetro".
Su ebay USA trovi motori "spark" in buone condizioni di funzionamento.
Never forget it.
dooling non è collegato   Rispondi citando
Vecchio 15 aprile 11, 16:05   #5 (permalink)  Top
re
grazie mille a tutti per l'interesse appena mi arriva allora forse saprò dirvi qualcosina in più,
mal che vada faccio come ha detto dooling (sotto vetro)
Vecchio 12 maggio 11, 13:32   #6 (permalink)  Top
arrivato ma è una glow?
salve a tutti mi è arrivato il motore questa mattina , l'ho smontato e sembra messo abbastanza bene,smontando la candela champion vg3 ho notato che non ha all'interno i due elettrodi ma bensì una spirale unita alla massa proprio come una candela glow
ma allora è una glow con le sembianze di una candela normale, qualcuno sa spiegarmi come funziona questa candela grazie!!!
Vecchio 12 maggio 11, 14:06   #7 (permalink)  Top
L'avatar di dooling
Los Merrecanos hanno la manìa di modificare, se è una glow, funziona come tutte le glow, batteria da 2 V, (eventualmente un diodo da 8 A in serie, per abbassare il voltaggio) e via andare.
Sempre che il motore sia in ordine.
Never forget it.
Vecchio 19 maggio 11, 09:16   #8 (permalink)  Top
L'avatar di pellikano
Data registr.: 22-03-2008
Residenza: Foligno
Le candele hanno lo stesso passo e quindi puoi adoperare una candela glow qualsiasi. Quella montata, se funzionante, ti consiglio di risparmiarla.
Il carter è O&R e così pare dal cilindro-testata. Per la posizione del carburatore devo informarmi. Io ho un O&R 29 nuovo di zecca e assomiglia moltissimo al blocco di ruggine che vedo in foto.
Non forzare nulla. Scalda (parecchio) con pistola ad aria prima e poi prova piano piano: le viti aspettano solo di essere forzate per spezzarsi.
...quello che noi chiamiamo "passione" altri dicono "mania". Dev'essere un bacillo veramente resistente che quando entra nel sangue non molla più. (Ninetto Ridenti) Arch. Cristiano Giustozzi FAI 10694. Tel. 393 9772747
pellikano non è collegato   Rispondi citando
Tutti gli orari sono GMT +1. Adesso sono le 14:34.
