Vecchio 18 settembre 12, 14:24   #1 (permalink)  Top
L'avatar di eriskio
Data registr.: 18-03-2010
Residenza: Genova
Immagini: 4
Radio Devention 8/8S - firmware OpenSource
Volevo informare che da pochi giorni è stata rilasciata la prima release del firmware OpenSource e Freeware per la radio Devention DEVO 8 e 8S (Walkera).
In breve:
"Deviation is a replacement firmware designed primarily for the Walkera Devo® series RC Transmitters. While Deviation is heavily influenced both by the Walkera DEVO8 firmware as well as by the Flysky/Turnighy based ER9X firmware, it has been written completely from scratch to be easily portable and extensible.
Major features include:
  • Support for multiple protocols without any modifications to the transmitter:
    • Walkera Devo 6/7/8/10/12
    • Walkera WK2401/WK2601/WK2801
    • Nine Eagles J6 Pro (requires telemetry module)
    • DSM2
    • DSMx (in progress)
  • Support for other protocols with very easy transmitter modifications
    • Flysky/Turnigy 9X
  • Support for up to 255 different models
  • Transmitter can act like a USB drive. Managing models, configuration, icons, and themes is as easy as copying a file...No more need to use the Walkera DfuSe tool.
  • Fully configurable themes including bitmaps, fonts, and colors
  • Flexible transmitter configuration. Support up-to 12 channels on a Devo8; remap any switches or buttons to any purpose
  • All text is localized. Available translations for Hungarian, German, French, and Russian. Adding a new translation is as easy as editing a text file, and copying it to the transmitter.
Per chi fosse interessato a provarlo/contribuire allo sviluppo il sito del progetto è questo: Home.
Hanno anche prodotto un emulatore dell'interfaccia per PC, in modo da poterne valutare le caratteristiche di programmabilità.
Ciao.
AGEM Genovamodel.it
eriskio non è collegato   Rispondi citando
Vecchio 18 settembre 12, 18:39   #2 (permalink)  Top
L'avatar di romoloman
Data registr.: 15-08-2007
il firmware supporta anche la devo 10
sarei anche interessato ma non ho la radio.. quindi la priorità va alla FrSky X12D
Grazie "TRANQUILLO"
FAI 15766
Vecchio 06 novembre 12, 02:21   #3 (permalink)  Top
L'avatar di BBC25185
Data registr.: 19-01-2007
Residenza: Dintorni di mestre (DINTORNI)
Per la devo10???
Non è uscito ancora nulla???
Inviato dal mio GT-I9100 con Tapatalk 2
BBC25185 non è collegato   Rispondi citando
Vecchio 06 novembre 12, 08:08   #4 (permalink)  Top
L'avatar di eriskio
Residenza: Genova
Immagini: 4
Originalmente inviato da BBC25185 Visualizza messaggio
Per la devo10???
E' in lavorazione, ancora non ufficialmente rilasciato.
Per il porting sulla 10 è stato necessario soprattutto rivedere tutta la parte grafica/visualizzazione perchè la 10 non ha un touchscreen a colori come la 6, la 8 e la 12.
E' disponibile la versione 1.1.2 per le Devo8/8S e 6/6S che è fondamentalmente funzionale.
Ci sono alcuni bug fix già pronti (compresa la traduzione in italiano ) ma stanno aspettando che la versione per la Devo10 sia consolidata in modo da poter rilasciare anche quella.
AGEM Genovamodel.it
Vecchio 19 novembre 12, 17:23   #5 (permalink)  Top
Data registr.: 28-06-2009
Residenza: napoli
Deviation Of DEVO10 Playing With Blades NANO CPX - YouTube
Interessante con la Devo 10 ..è lo stesso programma ?
edubu non è collegato   Rispondi citando
Vecchio 20 novembre 12, 08:49   #6 (permalink)  Top
L'avatar di eriskio
Residenza: Genova
Immagini: 4
Sì è lo stesso.
Solo che "ufficialmente" la versione per la DEVO10 non è ancora rilasciata. Puoi scaricarti i sorgenti e compilartela (come penso abbia fatto il tipo del video).
E' uno sviluppo "in progress" e però c'è molta attività intorno, piu' che quotidiana.
Io ho fatto un "freeze" della versione 1.1.2 per Devo8S, aggiungendo solo alcuni fix che mi interessavano, e la sto' usando sia con "vecchie" riceventi Walkera 2801 sia con un paio di Orange (DSM2) montate su un paio di combat in depron.
Ho poi realizzato una bella configurazione per i miei due vecchi micro Walkera 4G6S, in quanto con le possibilità di mix offerte da questo firmware (peraltro ripreso dai firmware per le Turnigy 9x) è possibile andare ben oltre le classiche curve a V, ma miscelare correttamente passo e comandi (alettoni, elevatore, timone) e viceversa ridurre proporzionalmente il passo in caso di concomitanza con comandi diversi: così il motore cala molto meno di giri nelle manovre e riesco (finalmente!) a fare un po' di acro anche con i 4G6S (volo rovescio, flip, roll, rainbow, piro) senza troppi pensieri (Sui 4G6S ho però RX bindabili in modalità 2801 cioè le RX2616V)
AGEM Genovamodel.it
Vecchio 27 novembre 12, 12:39   #7 (permalink)  Top
L'avatar di eriskio
Residenza: Genova
Immagini: 4
Versione 2.0.0 rilasciata
E' uscita oggi la versione 2.0.0 del firmware.
Principali novità:
Major Features:
  • Devo10 support
  • Telemetry support (for Devo)
  • New translations:
    • Traditional Chinese
    • Simplified Chinese
    • Romanian
    • Dutch
    • Italian (NOTA: se qualcuno trova imprecisioni/errori è pregato di scriverle qui, così correggiamo! )
Minor features:
  • Quickpages allow accessing frequently used pages
  • Fonts are stored on the filesystem
  • Mixers can be reordered
  • Channels can be reordered
  • New 'deadband' curve
  • DSM2 support upto 9 channels
  • Better WK2601 support
  • New Hubsan protocol
  • Power savings (auto-dim display)
  • New Max and Min muxes for the mixer page
  • Limits are applied live
  • Servo speed control
...più un certo numero di fix qui e là.
AGEM Genovamodel.it
Ultima modifica di eriskio : 27 novembre 12 alle ore 12:43
Vecchio 28 novembre 12, 16:55   #8 (permalink)  Top
Residenza: napoli
Question
Alla luce di questo nuovo firmware ..converrebbe la Devo 8S o la Devo 10 ?
Io prima o poi una DEVO la prendo
Vecchio 30 novembre 12, 08:55   #9 (permalink)  Top
L'avatar di eriskio
Residenza: Genova
Immagini: 4
Originalmente inviato da edubu Visualizza messaggio
Io ho preso una 8S, banalmente perchè mi piace il touchscreen a colori e una grafica un po' piu' "spinta" (anche se al sole si vedono male).
I canali non sono un problema: anche la 8S è "abilitata" fino a 12 (con le RX Devention sicuramente).
La 10 ha di piu' un paio di potenziometri "analogici" per controlli speciali, mentre i controlli della 8 sono praticamente gli stessi della vecchia TX2801 (a parte allo switch aux/gyro che sulla Devo8 è a 3 posizioni).
AGEM Genovamodel.it
Vecchio 24 gennaio 13, 15:16   #10 (permalink)  Top
L'avatar di matrixFLYER
Data registr.: 04-11-2011
Immagini: 15
Ciao risollevo questo thread per approfittare del fatto che hai esperienza con Walkera. Per caso hai avuto modo di provare una devo 10?
Se la risposta è no puoi comunque fare un confronto tra la Devo 8s che possiedi e non so una DX6i,dx7,dx8 a livello di qualità i movimento degli stick e qualità costruttiva in generale?
Sto leggendo che gli ultimi walkera stanno andando meglio e poiché ne sono sempre stato incuriosito quale momento migliore visto il DEVIATION per provare un combo di Super CP con TX Devo 7E o Devo 10.
La Devo 10 che a livello hardware di trasmissione penso sia identica alla devo 8s quanti mW di output ha? Si riescono ad avere 100mW? La portata è al pari di una DX6i?
Utilizzando anche aerei oltre che elicotteri la portata è fondamentale.
Perché in tal caso mi stuzzicherebbe molto l'idea di vendere la DX6i e farmi una Devo 10 come radio principale.
_____matrixFLYER_____
matrixFLYER non è collegato   Rispondi citando
problema con radio devention 7 walkera filpesp Radiocomandi 16 08 marzo 12 15:25
E' possibile caricare un firmware per AUTO su una radio con più di 4 canali? henry7612 Radiocomandi 0 10 agosto 09 18:15
Tutti gli orari sono GMT +2. Adesso sono le 02:36.
