Vecchio 23 gennaio 15, 10:54   #1 (permalink)  Top
Data registr.: 22-01-2013
Residenza: Pietragrande (CZ)
Il nuovo Aliante Multiplex Heron 2.4m
The MULTIPLEX HERON is a high-performance electric glider with T-tail and high-efficiency four-flap wing. With its elegant wings and flowing fuselage lines it responds superbly to thermals. When required, the efficient PERMAX brushless motor and folding propeller (RR version) deliver plenty of propulsive power. Its docile flying characteristics and excellent performance in the air ensure that the HERON provides a maximum of flying pleasure, whether you are a weekend pilot or an 'old hand'. You can enjoy floating through the air for long periods, as well as lively aerobatics - all with elegance and precision.
The extravagant four-flap wing with its extremely stiff CFRP / ALUMINIUM tubular spar technology sets entirely new standards in the 2.40 metre span class. The flaps are a standard feature, making pin-point landings child's play, improving the launch characteristics and giving the pilot a broad performance spectrum for high speed, aerobatics and thermalling.
Our tip is to fit out this exciting electric glider with our MULTIGyro G3, which effortlessly compensates for the effects of gusts and turbulence. The gyro gives you the sensation of piloting a perfectly trimmed, much larger model through the air.
The Heron is available as an RR version and in kit-form.
RR versions (factory-assembled model including motor and servos, servo extension leads, decals applied).
For the kit version we recommend the corresponding "HERON / SOLIUS" power set # 33 3660, which MULTIPLEX has selected to be a perfect match to the HERON, delivering a powerful, steep climb.
Among the outstanding features of this ELAPOR® model are the many new, innovative and extravagant detail features which ensure that it sets new standards in its class.
- Four-flap wing for high performance in the air (camber-changing flaps) and accurate spot-landings (butterfly / crow)
- Broad performance spectrum: high-speed, aerobatics, thermalling
- Innovative CFRP / ALUMINIUM tubular spar technology for strong, stiff wings
- GRP "M-SPACE technology" for a rigid fuselage
- RR version includes high-power brushless motor and folding propeller
- clear canopy with highly detailed cockpit
- Detachable wings and tailplane for ease of transport
The Condor non è collegato   Rispondi citando
Vecchio 23 gennaio 15, 11:34   #2 (permalink)  Top
L'avatar di Tiaz10
Data registr.: 11-02-2014
Residenza: San Marino
molto bello, immagino che costerà come un modello in fibra pero!
Elicaaaaaaaaaaa
Tiaz10 non è collegato   Rispondi citando
Vecchio 23 gennaio 15, 14:21   #3 (permalink)  Top
Data registr.: 19-03-2007
Residenza: lecco
lo prendo stavo x prendere il solius ma ciapo questo...gianni
ducati non è collegato   Rispondi citando
Vecchio 23 gennaio 15, 16:17   #4 (permalink)  Top
L'avatar di david
Data registr.: 16-10-2011
Residenza: Abano T.
sui video della casa vanno tutti benissimo, cmq ho trovato questo: HERON aus ELAPOR®, 2400mm, 4-Klappen-Flügel, Rohrholm, Multiplex # 214276 | Multiplex | Segelflugmodelle | Flächenmodelle | Flugmodelle / Helis / Quadcopter neanche male....
david non è collegato   Rispondi citando
Vecchio 23 gennaio 15, 16:42   #5 (permalink)  Top
L'avatar di Tiaz10
Senza elettronica però mi sembra di aver capito.... Poi tra motore, regolatore batterie e sei servi altri 50/60 euro ci vogliono tutti!
Elicaaaaaaaaaaa
Vecchio 24 gennaio 15, 12:52   #7 (permalink)  Top
Prima recensione
Trovate la prima recensione del modello a questo link
http://www.test.modellpilot.eu/heron...x-modellsport/
dovete però prima registrarvi come ospite
Vecchio 24 gennaio 15, 14:06   #8 (permalink)  Top
Originalmente inviato da The Condor Visualizza messaggio
Il link corretto
HERON MULTIPLEX Modellsport Video Testbericht Elektrosegelflugzeug : HERON MULTIPLEX
Vecchio 24 gennaio 15, 14:23   #9 (permalink)  Top
Al tipo che ha fatto la recensione qualcuno dovrebbe dirgli che ha a che fare con un aliante .....
Vecchio 25 gennaio 15, 03:29   #10 (permalink)  Top
L'avatar di Ste41
Data registr.: 27-04-2006
Residenza: Zanica (Bg)
Originalmente inviato da david Visualizza messaggio
Al confronto di alianti dello stesso prezzo, sullo stesso sito, il confronto è impietoso. Costa tanto, per avere poco
[VENDO] aliante Multiplex TWIST MicheTN Merc. Aeromodellismo 0 07 aprile 14 13:34
Aliante by Multiplex??? Nobody Aeromodellismo 17 12 agosto 10 08:10
dg 300 multiplex come aliante per traino nicthepic Aeromodellismo Aerotraino 6 27 aprile 10 15:02
aliante flamingo multiplex nicthepic Aeromodellismo 1 21 aprile 05 17:59
Tutti gli orari sono GMT +2. Adesso sono le 10:47.
