Vecchio 16 maggio 08, 20:34   #1 (permalink)  Top
L'avatar di mikenet76
Data registr.: 04-11-2005
Residenza: Ferrara
Latenza DX7 e Futaba 12z, video dimostrativo a 1200 fps.
A puro spirito divulgativo, ho trovato questo video sul tema latenza:
Può interessare?
I took a high speed 1200 fps video of a Spektrum DX7 rc transmitter (2.4ghz) installed next to the trex 600 that it was controlling, focusing on the transmitter's stick and the trex 600's swash plate.
The transmitter stick was then held back and then let go to see how long it took for the swash movement. Each frame of the video is under a millisecond of time (0.83) and it is displaying at 30 fps. What is interesting is I stepped through the frames one by one and it appears to take about 57 frames from the time the stick was let go to the time the swashplate started to move which equals about 47.5 milliseconds. I was actually surprised by that because I expected under 10 milliseconds. Futaba's 2.4ghz module on a Futaba 12z showed the same latency time too.
Video taken with the ex-f1 camera.
e poi:
I took a high speed 1200 fps video of a Futaba 12z rc transmitter (I think that is the model) with the Futaba 2.4ghz module installed next to the trex 600 that it was controlling, focusing on the transmitter's stick and the trex 600's swash plate.
The transmitter stick was then held back and then let go to see how long it took for the swash movement. Each frame of the video is under a millisecond of time (0.83) and it is displaying at 30 fps. What is interesting is I stepped through the frames one by one and it appears to take about 57 frames from the time the stick was let go to the time the swashplate started to move which equals about 47.5 milliseconds. I was actually surprised by that because I expected under 10 milliseconds. Spektrum's transmitter showed the same tx to swash latency so that must be normal.
Ultima modifica di mikenet76 : 16 maggio 08 alle ore 20:42 Motivo: completezza dell'informazione
mikenet76 non è collegato   Rispondi citando
Latenza, risoluzione, software.... scelta per nuovo TX enry74 Radiocomandi 5 21 aprile 08 15:06
Meccaniche eCCPM 120°, miscelazione eCCPM, risoluzione 1024/2048, latenza etc etc rc_addicted Elimodellismo in Generale 22 30 agosto 07 16:42
Video setup Spektrum DX7 DSM2 nigel_uno Radiocomandi 36 30 agosto 07 10:19
peso 7 celle 1200 a easifli Aeromodellismo Volo Elettrico 0 08 ottobre 04 21:03
Tutti gli orari sono GMT +2. Adesso sono le 11:49.
