Vecchio 02 gennaio 14, 22:53   #1 (permalink)  Top
Data registr.: 04-02-2013
Residenza: Bergamo
Turnigy 9X fw originale come abilitare switch 3 posiz.
Ciao,
come da titolo ecco cosa impostare, credo sia utile per abilitare lo
switch 3 posizioni.
Si attiva sul canale 7!
This is what works for me. I use this on my MWC. Someone here claimed it didn't work for them, but it's worked every time for me.
1. Go to the AUX-CH menu and set CH6 to "PIT TRIM'
The Pitch Trim dial will be the "basis" for the mix, leave it at FULL, turned all the way clock wise.
2. Go to PROG-MIX menu and enter MIX 1, then enter the following settings
STATE ACT
MASTER FLP
SLAVE AUX (The first one)
OFFSET -100
UPRATE -100
DNRATE -100
SW NOR
3. Go in to MIX 2 and enter the following settings
STATE ACT
MASTER FLP
SLAVE AUX
OFFSET 000
UPRATE 100
DNRATE 100
SW ID2
That's it! Go to the DISPLAY menu and you can see that channel 7 is now being activated by the 3-position switch with low, mid, high output for the 3 positions. You can now connect channel 7 of your Rx to the Mode input of the MWC and it will activate the three settings.
Took me a while of trial and error to figure out.
(Note, you can turn the Pitch Trim dial all the way down and it will reverse the operation of the switch. Up will be High, mid-mid, and down will be Low if you prefer that configuration for whatever reason)
Preso da RCgroups, io ho provato e funziona!
Prima o poi passerò a openTX
La mia pagina Facebook --> http://www.facebook.com/ivan.riva.587
La mia pagina Youtube --> http://www.youtube.com/user/Jvani83
Jvan83 non è collegato   Rispondi citando
Switch error con turnigy 9x bobrock Radiocomandi 2 30 marzo 13 21:53
Butterfly su Turnigy 9x originale angioletto72 Radiocomandi 2 27 luglio 12 19:26
turnigy 9x switch 3 posizioni giacomo801 Radiocomandi 8 20 luglio 12 18:55
Turnigy 9x ORIGINALE - pregi e difetti? CarloRoma63 Radiocomandi 21 03 febbraio 12 20:48
Tutti gli orari sono GMT +1. Adesso sono le 03:01.
