Vecchio 11 agosto 12, 15:44   #3111 (permalink)  Top
L'avatar di AlexBooo
Data registr.: 27-02-2012
Sembra interessante, sperando che non hanno introdotto nuovi bug. Chi fa da cavia?
Certo se le corse vanno a donnine allegre è na bella rottura...
AlexBooo non è collegato   Rispondi citando
Vecchio 11 agosto 12, 15:50   #3112 (permalink)  Top
L'avatar di BBC25185
Data registr.: 19-01-2007
Originalmente inviato da AlexBooo Visualizza messaggio
Sicuramente, appena ne avrò la possibilità, lo metto!!!
Vecchio 12 agosto 12, 20:52   #3113 (permalink)  Top
L'avatar di m.rik
Data registr.: 28-06-2005
È disponibile AirWare 2.05 😊
Version 2.05
10 August 2012
Software Features
• Added support for GPS and High Current telemetry sensors.
• Enabled up to 32-pole motors for the brushless RPM sensor.
• Enabled SD telemetry log file
• Enabled ability to configure inactivity timer
• Enabled backlight configurability (Auto/On/Off)
• Enabled dimming control of the orange Spektrum LED for night flying
• Adjusted vibe motor RPM to be less aggressive
Software Corrections
• Fixed bug that could reset the radio when scrolling through Mix options.
• Corrected L/R trimmer ‘forgetting’ assignment after power cycle.
• Improved translations in French and Italian screens.
• Corrected export of flap configuration.
• Corrected over-travel of flaps that could result in reversed operation at extreme deployments.
• Corrected switch change on Acro throttle cut screen when going from the initial switch selection to the edit page.
• Corrected timer to work properly in Throttle Out mode when using reversed throttle channel.
• Corrected end-point adjustability when Trainer is used as an input to a channel.
• Corrected trainer normal Master mode so that it doesn’t modify controls from the
slave. In previous versions it could reverse channels vs. what was expected.
NOTE: This change affects sub-trim and travel of existing models and ones you will import. You may need to adjust sub-trims and travel on all control surfaces in both airplanes and helicopters.
Egidio
volevo già farlo per altre tue precedenti segnalazioni / link.
Lo faccio ora:
Grazie Egidio.
Con quest'ultima però, quando l'ho ricevuta sul telefonino, ho piantato tutto e tutti e quando sono finalmente tornato a casa per scaricarla ed installarla sono rimasto a bocca asciutta.
La prossima volta, scrivi "coming soon", e non "è disponibile".
m.rik non è collegato   Rispondi citando
Vecchio 13 agosto 12, 00:15   #3114 (permalink)  Top
L'avatar di AEROX_15
Data registr.: 18-06-2009
Residenza: Treviso
Ancora niente purtroppo, e siamo al 12 agosto...
Siamo sicuri sia veramente disponibile?
Vecchio 13 agosto 12, 00:32   #3115 (permalink)  Top
L'avatar di double68
Data registr.: 27-05-2009
Residenza: Piacenza
Pazientiamo in religioso silenzio... 😔
Vecchio 13 agosto 12, 00:41   #3116 (permalink)  Top
Residenza: Treviso
L'attesa si fa sentire!!
Vecchio 13 agosto 12, 08:15   #3117 (permalink)  Top
Che esagerati, che è st'attesa spasmodica...
Vecchio 13 agosto 12, 13:02   #3118 (permalink)  Top
Residenza: Treviso
vogliamo l'upgrade !!!!!!!!
Vecchio 13 agosto 12, 14:09   #3119 (permalink)  Top
Inviato dal mio GT-I9100 con Tapatalk 2
Vecchio 13 agosto 12, 15:01   #3120 (permalink)  Top
Residenza: Treviso
Version 2.05
10 August 2012
Software Features
Egidio
Egidio dove hai trovato questa notizia ??
ci stanno facendo aspettare un po troppo con questo upgrade Non vorrei mai che sia tutto una bufala
Tutti gli orari sono GMT +2. Adesso sono le 12:01.
