Vecchio 02 agosto 12, 21:36   #3101 (permalink)  Top
Data registr.: 19-03-2007
Residenza: lecco
Ma io ho provato col tuttala ed e andato tutto bene led fisso sia su rcv che sat. Chi la detto mi spiegava che cosi il binding e immediato e piu sicuro provare ho provato e andava bene pero io qui in montagna ho solo rcv orange con l originale provero a casa...gianni
ducati non è collegato   Rispondi citando
Vecchio 11 agosto 12, 11:05   #3102 (permalink)  Top
L'avatar di egicar
Data registr.: 08-04-2007
Residenza: Nuvolera (BS)
È disponibile AirWare 2.05 😊
Version 2.05
10 August 2012
Software Features
• Added support for GPS and High Current telemetry sensors.
• Enabled up to 32-pole motors for the brushless RPM sensor.
• Enabled SD telemetry log file
• Enabled ability to configure inactivity timer
• Enabled backlight configurability (Auto/On/Off)
• Enabled dimming control of the orange Spektrum LED for night flying
• Adjusted vibe motor RPM to be less aggressive
Software Corrections
• Fixed bug that could reset the radio when scrolling through Mix options.
• Corrected L/R trimmer ‘forgetting’ assignment after power cycle.
• Improved translations in French and Italian screens.
• Corrected export of flap configuration.
• Corrected over-travel of flaps that could result in reversed operation at extreme deployments.
• Corrected switch change on Acro throttle cut screen when going from the initial switch selection to the edit page.
• Corrected timer to work properly in Throttle Out mode when using reversed throttle channel.
• Corrected end-point adjustability when Trainer is used as an input to a channel.
• Corrected trainer normal Master mode so that it doesn’t modify controls from the
slave. In previous versions it could reverse channels vs. what was expected.
NOTE: This change affects sub-trim and travel of existing models and ones you will import. You may need to adjust sub-trims and travel on all control surfaces in both airplanes and helicopters.
Egidio
Vecchio 11 agosto 12, 11:31   #3103 (permalink)  Top
L'avatar di liftbag
Data registr.: 10-03-2010
Version 2.05
10 August 2012
Software Features
Egidio
Mmm, non è ancora disponibile alla mia pagina della Community
Vecchio 11 agosto 12, 11:38   #3104 (permalink)  Top
L'avatar di veleno71
Data registr.: 21-05-2008
Residenza: Gravina di Catania
Invia un messaggio via MSN a veleno71
Da me non compare nessun aggiornamento.
Non digerendo bene l'inglese, se qualcuno volesse tradurre ne saremmo contenti.
Come ultima domanda, ho capito bene che dopo questo aggiornamento si deve risettare tutti i modelli?
Buone ferie a tutti, anche se io ancora sto lavorando.
veleno71 non è collegato   Rispondi citando
Vecchio 11 agosto 12, 12:16   #3105 (permalink)  Top
L'avatar di BBC25185
Data registr.: 19-01-2007
anche da me non compare l'aggiornamento!!!!
Comunque finalmente hanno inserito il sensore di corrente e il log della telemetria su SD...
Per chi non sà l'inglese:
AGGIUNTE:
Aggiunto supporto per il GPS e per il sensore di corrente
Aggiunta la possibilità di usare motori fino a 32 poli con il sensore di giri per motori brushless
Aggiunto il salvataggio del Log della telemetria su SD
Aggiunta possibilità di modificare il tempo di inattività
Aggiunta possibilità di accendere e spegnere la luce dello schermo (Auto, ON, OFF)
Aggiunto il controllo di luminosità del simbolo arancione spektrum per il volo notturno
Possibilità di modificare la vibrazione
CORREZZIONI:
Sistemato il bug del reset della radio mentre si scorre nel menù MIX
Corretti i trimmer L/R che perdono l'assegnamento dopo lo spegnimento
Migliorato la traduzione in Francese e Italiano
Corretto l'esportazione della configurazione dei FLAP
Corretto l'over-corsa dei flap che potevano portare all'operazione inversa in caso di estrema corsa
Corretto il cambio di switch del Cut Off del gas quando si è nel menu iniziale della selezione degli switch
Corretto il timer che lavora con il GAS quando lo si usa con il gas invertito
Corretto la variazione della corsa massima quando la porta trainer viene usato come input per un canale
Corretto la modalità Trainer Master in modo che non modifica più i controlli dallo Slave
NOTA: Queste modifiche alterano i Sub-Trim e le corse dei modelli esistenti e di quelli importati tramite SD...
è necessario sistemare i Sub-Trim e le corse di ogni comando sia sugli elicotteri che sugli aerei!!!
Vecchio 11 agosto 12, 13:16   #3106 (permalink)  Top
L'avatar di double68
Data registr.: 27-05-2009
Residenza: Piacenza
Grazie a tutti per la segnalazione e la traduzione, ora aspettiamo che sia disponibile x il download. Una bella sorpresa estiva direi!!!
Vecchio 11 agosto 12, 15:10   #3107 (permalink)  Top
L'avatar di dex1
Data registr.: 19-01-2005
Residenza: 33170 e dintorni
mha!
egi sei sicuro?
per me ce' l'aggiornamento e x la DX10 e la DX18 non la DX8.
Vecchio 11 agosto 12, 15:19   #3108 (permalink)  Top
Residenza: Piacenza
mha!
egi sei sicuro?
Il Bug ė perfettamente corrispondente quindi c'ė del vero, sicuramente Egi ci ha dato una news non ancora ufficializzata.
Ho provato a cercare in giro e in effetti di AirWare 2.05 non ne parla ancora quasi nessuno.
Sarà stato appena sfornato!
Inviato con Tapatalk
Vecchio 11 agosto 12, 15:23   #3109 (permalink)  Top
L'avatar di egicar
Tranquilli 😉
Se già non lo avete su Spektrum Community, è questione di molto poco.
P.S: non chiedetemi di più 😷
Ultima modifica di egicar : 11 agosto 12 alle ore 15:33
Vecchio 11 agosto 12, 15:36   #3110 (permalink)  Top
Residenza: Piacenza
Ricevuto - passo e chiudo
Tutti gli orari sono GMT +2. Adesso sono le 18:40.
