Discussione chiusa
Vecchio 16 gennaio 13, 13:36   #1 (permalink)  Top
L'avatar di cillyjr
Data registr.: 10-07-2011
Residenza: prov modena
450SE V2 - ARF - Codename Red Ed
450 SE V2 - ARF
-Motore RCX 3800kv
-ESC RCX 40A
-Servi ciclico Esky EK2-0508
-Servo coda KDS-2004-2 N590:
--Digital servo
--Speed: 0.08/60 4.8V 0.07/60 6.0V
--Torque: 2.0kg/cm 4.8V 2.5kg/cm 6.0V
--Operating frequency(Hz): 300
--Dimension: 35.5mm x 15mm x 28.6mm
--Weight: 25g
-Gyro Hobbywing G3 (Mems, avcs+normal - sito - manuale)
--1 Specification
--1.1 Input: 4.5-6.5V, operating current = 50mA, maximum current <100mA.
--1.2 Size: 26mm*24mm*9mm.
--1.3 Weight: 12g.
--1.4 Suitable Servo:
---Standard digital servos, frequency 333Hz, servo neutral point: 1520us.
---Narrow band digital servos, frequency 560Hz, servo neutral point: 760us.
--2 Features
--2.1 Dual working modes: Normal mode and Head-lock mode, switched by the sensitivity value of the GAIN channel of your transmitter.
--2.2 Compatible with standard digtal servo and narrow band digital servo.
--2.3 User programmable.
--2.4 Uses advanced MEMS (Micro Electro Mechanical Systems) angular rate sensor to get super performance.
--2.5 Advanced algorithm: AVCS (Angular Vector Control System) algorithm provides best tail-control performance.
--2.6 Built-in temperature compensation circuit eliminates the drift caused by environment temperature changing.
--2.7 Completely digitalized to make the gyro more reliable: Each programmable value is adjusted by a SET button without any analog component such as trimming potentiometer.
Upgrade (v.foto):
-red metal landing skid;
-turnbuckles pitch link for blade tracking;
Montato (salvo esigenze spedizione), settato e perfettamente funzionante.
Prezzo: €170,00+ss
Possibilità versione BNF Spektrum con radio orange 6 canali + satellite = +25€
Possibilità valigia porta heli e radio = + 40€
Foto, info ed eventuali (tanti) ricambi disponibili a richiesta.
La consegna a mano è preferibile: emilia e basso veneto no prob; altre località possono essere concordate.
Siate magnanimi per eventuali commenti. Prima inserzione.
La legislazione vigente nell'Unione Europea prevede che anche i privati siano tenuti a dare garanzia sugli oggetti venduti a meno che tale garanzia non sia esplicitamente esclusa al momento della vendita.
L'oggetto qui proposto è perfettamente funzionante all'atto della spedizione, esso è venduto "così com'è", con esclusione esplicita di qualsiasi forma di garanzia.
Chi dovesse fare offerte per l'oggetto proposto con la sua offerta accetta quanto sopra.
Nome: Giovanni
Cognome: Cilia
Città: Mirandola - Prov. MO
...più facile montarli che volarli...o era montarle?!
Ultima modifica di cillyjr : 16 gennaio 13 alle ore 13:38 Motivo: correzione titolo
cillyjr non è collegato
Vecchio 11 marzo 13, 17:18   #2 (permalink)  Top
L'avatar di cillyjr
uppolo...
aggiungo un video ed un po' di ricambi (vari) nel kit, sperando aiutino...
ps. posso sostituire il gyro con assan-ga250 (o CX-GY240) riducendo di 25 (o 30)€ il prezzo.
Vecchio 26 marzo 13, 15:31   #3 (permalink)  Top
L'avatar di cillyjr
Sold out
venduto altrove (non proprio come speravo, ma...)!
si può chiudere (basta scriverlo o devo fare altro?).
grazie.
Discussione chiusa
Compatibilità elettronica t-rex 450se v2 in un t-rex 450s ARF Ombra Elimodellismo Motore Elettrico 1 27 luglio 10 19:13
Gl 450se elicoberna Elimodellismo Motore Elettrico 12 26 dicembre 07 18:41
Tutti gli orari sono GMT +1. Adesso sono le 16:18.
