Vecchio 01 dicembre 10, 02:12   #1 (permalink)  Top
L'avatar di Eris19xx
Data registr.: 28-05-2009
Residenza: Belgium
Exceed RC Robo Helicopter RTF
Evviva lo hanno fatto ...
me lo compro 149USD
Exceed RC Robo Helicopter series has a huge success since it hit the market, thanks for the Bell Rotor Head system, the helicopter flies like no one else, the 45 degrees flybar makes the Exceed RC Robo Helicopter flies like a Co-Axial Helicopter, which is a dream to fly for beginners. Now Exceed RC decided to boost up the performance, by adding all the good electronics in it, like a 3800kv Brushless Motor, Shaft Driven Tail Rotor, High Speed Rudder Servo and most of all, the 3-Axis Gyro with Auto Stabilizing Technology, this makes the Exceed RC Robo Helicopter even more easier to fly!
Since the Exceed RC Robo Helicopter is the Ultimate mode, it has the 2.4G radio system and metal upgrades as well, that makes it more Durable and more Precise.
Feature:
4 Channel remote control set includes complete Forward/Backward, Left/Right, Up/Down control (RUDDER, AILERON, ELEVATOR, AND THROTTLE)
New 2.4 GHz Spread Spectrum Transmitter, Awesome Look Cabin, Reliable Spread Spectrum Mixer/Gyro Control, More Stable Flight, Even First Timer can Control Easily
New 2.4GHz technology, with the functions of automatic identification and precise code pairing, strong anti-jamming, and allow more than 20 aircrafts to fly at the same field at same time
4-Channel 2.4GHz transmitter with digital LCD display
Latest 3D Mixer/Gyro Control Technology for those "Serious" beginners who demands performance between Basic Fixed Pitch Helicopters and Basic Collective Pitch Helicopters!
Newest CNC metal rotor head and tail for durability and performance
Newest state-of-the-art high performance 3D gyro (using same technology as in high-end professional helicopters) for extreme precision and stability!
Newest Compact swashplate structure with light-fine canopy for super stable flight
Newest reliable Super Performance 3800Kv brushless motor
Digital high speed rudder servo for maximum efficiency and accuracy
Super precision shaft-driven tail rotor -- it is powered by the main motor, which is more direct, precise and much more reliable than individual tail motor and would not worn out after a period of time
Solid servo mounts for precise control
Screw-on frame for easy repair
Factory Pre- assembled, zero assembly time
Suitable for Indoor/Outdoor/Backyard/Park
The main rotor blades are using top quality plastic materials, which is not easily break
Approximately 10 minutes flight time on each charge
Complete Kit, Ready to Fly (Everything is included and 100% assembled -- only required 8 AA batteries for the transmitter to start flying)
Specification:
Main Rotor Diameter: 452mm (17.7 inch)
Tail Rotor Diameter: 94mm (3.7 inch)
Overall Length: 400mm (15.7inch)
Flying Weight: 320g (battery included) (11.2 oz)
Gyro: Latest technology professional super performance 3D gyro
Driven system: 3800Kv brushless motor
Speed Controller: 20A brushless ESC
Servo: 2X 8.5g servos + 1x digital high speed tail servo
Battery: 7.4V 1200mAh Li-Polymer
Control system: 4CH Multifunctional 2.4 GHz Transmitter and Receiver
Radio Control Range: 330 degree feet (1000m)
Package Include:
Exceed RC Robo Helicopter (100% Assembled)
4 Channel 2.4 GHz Spread Spectrum Multifunctional R/C Transmitter w/ LCD Display,
Wall Battery Balance Charger
High Quality 7.4V 1200mah Li-Po Rechargeable Battery
Extra Set of Main Blades
English Manual
Mini Titan 325 SE | T-REX 250SE| The monster..... Trex 700 LE
_______________________________
Futaba 10CG 2.4G FASST
Eris19xx non è collegato   Rispondi citando
Vecchio 01 dicembre 10, 16:21   #2 (permalink)  Top
L'avatar di fulvior.
Data registr.: 03-11-2010
Residenza: ROMA
che ha di particolare oltre all'estetica?
fulvior. non è collegato   Rispondi citando
xiang yan helicopter clod8 Elimodellismo Principianti 5 02 novembre 07 17:34
3dx 450 full cnc rc helicopter kit V4D poppi79 Elimodellismo Motore Elettrico 0 10 settembre 07 17:30
Mini helicopter 7EO86 Elimodellismo Principianti 13 10 luglio 07 17:36
First Helicopter scorpion69 Elimodellismo Principianti 8 10 giugno 07 14:55
Hirobo XRB Sky robo .. indomabile tittipillo Elimodellismo Principianti 3 07 ottobre 06 20:36
Tutti gli orari sono GMT +2. Adesso sono le 15:26.
