| | #1 (permalink) Top |
| User Data registr.: 05-09-2007
| regolatore mystery 100a.che ne pensate??
raga' ho preso un regolatore mystery 100ampere Size: 74.4mm x 39.1mm x 15.9mm Constant Current: 100A Max Current: 110A/12s Input Volt: 6 - 22.2V Low-Voltage Cutoff: Auto detect and set Advantage of the Mystery Speed Controller Low resistence High rate PWM User programmable brake Low voltage auto setting based on battery Throttle range self-adjusting Soft start ramp up Runs motor in forward or reverse Auto motor cutoff with reset Safe power arming program ensures motor will not run accidentally after turn on Low torque start Auto shut down when signal is lost andra' bene per il mio t-rex 500???vorrei cambiare il mio align ....che ne dite??? |
| Bookmarks |
| mystery 100A..istruzioni? help!! | greg89 | Aeromodellismo Volo Elettrico | 3 | 28 dicembre 08 00:55 |
