Discussione: winch Futaba S5801
Vecchio 26 marzo 08, 13:44   #1 (permalink)  Top
TONICLE
L'avatar di TONICLE
Data registr.: 01-05-2007
Residenza: Castellammare di Stabia (Na)
winch Futaba S5801
cosa ne pensate di questo servo?
va bene per tirare le vele di una iom?
new Futaba S5801 Servo Sail Winch
This is a Sail Control Winch Servo that has proper Winching Action with a Drum (rather than servo arms like other "sail winch" servos).
FEATURES:
High Torque and High Speed
BEC set-up (a 5-6 cell pack powers the winch and the receiver the same way an Electronic Speed Control would)
Water Resistant
5-pole motor
Metal Gears
Two Ball Bearing
Adjustable Trimmer (adjusts from two to six 360° revolutions) as increasing number of revolutions are dialed in, speed increases
INCLUDES:
One S5801 Sail Winch Servo (Futaba J Receiver Plug, ON/OFF Switch and Tamiya-style battery plug)
One Drum Adjuster Plastic Screwdriver
One Illustrated Instructions Sheet
SPECS:
Torque: 109 oz-in @ 6V - 136 oz-in @ 7.2V; (7.8 kg-cm @ 6V - 9.8 kg-cm @ 7.2V)
Servo Speed: .6 sec/360° rotation @ 6V; .5 sec/360° rotation @ 7.2V
Drum Travel: 2 to 6 Revolutions (adjustment range)
Drum Diameter: 1.6" (42mm)
Length: 1.8" (46mm) (excluding drum and mount flanges)
Width: 1" (25.4mm)
Height: 1.8" (46mm)
Weight: 2.9oz (83g)
TONICLE non è collegato   Rispondi citando
