26 aprile 05, 16:56
#2 (permalink)
Top |
| User
Data registr.: 31-01-2005 Residenza: Genova
| Citazione: Originally posted by Odi@26 aprile 2005, 15:43 E in Inglese:
RC scale glider. For 7-channel radio control. Semi-scale model for slope, winch and aero-tow. Quick-build kit incl. white pigmented epoxy fuselage, ready-made wings and tailplane, decal sheet, linkage hardware pack.
Product information
The Ventus 2c, made by the Schempp-Hirth company, is a racing class sailplane, designed and manufactured in accordance with the latest research. The glider can be flown with a wingspan of 15 or 18 m. The movements of the ailerons and camber-changing flaps are 100% superimposed, making the machine highly manoeuvrable. Some of the models dimensions have been altered slightly from true scale, to ensure that the model has superb flying performance and handling. Just like the original machine, the model features ailerons and camber-changing flaps. If the full-span flaps are deployed correctly, the VENTUS 2c has an exceptionally broad speed range. The very highly pre-fabricated GRP fuselage, GRP rudder, and sandwich-construction wings and tailplane simplify construction of the model very greatly. The inboard wing panels feature a strong I-section wood/CFRP spar, into which the sleeve for the 18 mm round steel joiner rod is integrated. The wings and tailplane are supplied in the kit as ready-made items, i.e. leading edges are in place and sanded, airbrake boxes installed, servo wells machined, and sleeves for the 18 mm Ø round steel wing joiner factory-fitted. An optional retractable wheel and aero-tow coupling can also be installed. The fuselage features precision-cut holes, ensuring accurate wing location. Machined formers are supplied in the kit to accept the retract unit. The outboard wing panels are attached to the inboard panels by means of a 10 mm Ø round steel joiner and clamping screw.
Contents of the quick-build kit
Building instructions in German, English and French. White pigmented GRP fuselage, obechi-skinned wing panels and tailplane, GRP rudder, undercarriage formers, 18 mm steel wing joiner, GRP canopy frame, CNC-machined canopy, covering film, decal sheet, small parts, linkage hardware pack.
RC functions
Rudder; Elevator; Ailerons; Camber-changing flaps; Airbrakes; Aero-tow release; Retract unit; Wheelbrake.
Ensemble R/C conseillé
Système à micro-ordinateur GRAUPNER mc-24 dans la bande des 41 MHz; voir dans le catalogue général GRAUPNER FS.
Specification
Wingspan approx. 5500 mm
Fuselage length approx. 1970 mm
Overall length approx. 2064 mm
Wing section HQ/W 3/13
Tailplane section HQ/W 0/10
Wing area approx. 104 dm²
Tailplane area approx. 9.4 dm²
Total surface area approx. 113.4 dm²
Weight according to fittings approx. 9800 g | é una bella bestiola ......
Graupner
Fabio Genoa Slope Soaring Team |
