08 giugno 07, 12:57
#5 (permalink)
Top |
| User
Data registr.: 04-02-2005
Si, infatti é "molto" più spesso... Citazione:
"With experience from other well known DLG designs like Aspirin, Fireworks 2 and 3, Kisal, Turbo and XP4 we have been able to cherry pick the advantages of each design and create a DLG that will give some more percents of performance....snip........from the demands (technical/customer) on a high performace DLG glider ,that one can use in all weather conditions, we got the following characteristics, strength, stiffness,penetration, sinkrate etc. Technical solutions living up to these demands are a big wing with thick airfoil. With this the concept was set and the really time consuming iteration in X-foil began to create a airfoil with lower drag than the Drela Airfoils, but thicker. The result was a wing with bigger area compared to the rest of the European designs and a airfoil with 7,5 % thickness.The new airfoil together with the wide chord do make the wing thick, this is a good base for strength, stiffness and at the same time there is room for wing mounted servos. High attention, during the design work of the airfoil, has been to get a design that avoids flutter (my note: on flaperrons)."
| Dal 3d su RCGoups: http://www.rcgroups.com/forums/showt...ghlight=sirius |
