25 novembre 21, 13:10
#2 (permalink)
Top |
| User
Data registr.: 05-09-2005 Residenza: Breganze (VI)
Originalmente inviato da msette Dovrebbe essere la nominale, in quanto la casa dichiara un range tra 4.8 e 8.4 V D625MW 32-Bit, High Speed, Metal Gear Servo
Product Description
The metal D-625MW is part of our D-Series servo line. All Hitec D-Series servos have been designed using our brand new, cutting edge, custom engineering. Combining industry leading high-resolution, state-of-the-art ultra-response technology with a 32-bit MCU and 12-bit ADC for unprecedented programmability and flexibility, these servos deliver significantly smoother movement. The speedy, powerful line operates on a wide 4.8 ~ 8.4 voltage range, allowing use with any common battery chemistry without the need for adapters or regulators. Featuring Hitec’s industry standard 25-tooth output spline with 3mm hex screw, each D-Series servo brings monster performance never known before in the market. | Grazie
www.gal-laverda.com
