Originalmente inviato da carletttta "volgare" servo digi da 30€
Operating Temperature: 14° - 122°F (-10° - 50°C)
Running Current (no load): 180mA @6.0V, 240mA @7.4V
Stall Current (at locked): 1300mA @6.0 V, 1600mA @7.4V
Idle Current: 5mA @6.0V, 5mA @7.4V
Wire Length: 300 ± 5mm
Output Gear Spline: 25 Tooth
Bearings: 1BB
Operating Travel: 120° (1000 → 2000 µ second)
Neutral Position: 1500 µ second
Pulse Width Range: 800 → 2200 µ second
Maximum Travel: Appx 164° (800 → 2200 µ second)
Refresh Rate: 240 Hz
Motor Type: Brushed |
ah bhe allora con i Savox siamo in una botte di ferro !
SV1270TG - High Voltage Coreless Digital Servo, .11/486.1 @ 7.4V
Technical Details
Running Current (no load): 120mA @6.0V, 150mA @7.4V
Stall Current (at locked): 5500mA @6.0 V, 6800mA @7.4V
Idle Current: 5mA @4.8V, 5mA @6.0V
Wire Length: 200 ± 5mm
Bearings: 2BB
Operating Travel: 100° (1000 → 2000 µ second)
Maximum Travel: Appx 130° (900 → 2100 µ second)
Refresh Rate: 333 Hz
Motor Type: Coreless
