Vecchio 23 ottobre 20, 14:55   #31 (permalink)  Top
windsurfer
L'avatar di windsurfer
Data registr.: 08-05-2012
Residenza: Trieste
Originalmente inviato da blue61 Visualizza messaggio
questa e la procedura di binding che mi ha dato spektrum;
Yes, the DX6 black should work well with the mcpx V2.
It is very important that you follow this exact binding process:
Binding Procedure for Computer Radios
1. Disconnect the flight battery from the helicopter.
2. Power off the transmitter and move all switches to the 0 position.
3. Connect the flight battery to the helicopter. The 3-in-1 Control unit LED flashes after 5 seconds.
4. Push the bind switch/button while powering on the transmitter.
5. After 2–3 seconds, release the bind switch/button.
6. Move the rudder control stick to full right. Continue to hold the rudder control stick to full right until the blue LED on the 3-in-1 control unit is solid.
7. Release the rudder control stick.
8. Disconnect the flight battery and power the transmitter off
Step 6 is very important!!
praticemente, io non spostavo lo stik alettoni verso destra dopo aver mollato il pulsante di binding.....
E' la normale procedura per bindare l'mCP X V2, descritta nel manuale in italiano a pag.54. Ma hai il manuale originale?
ELI:mCPX,SoloPro228A,V911,E160#AEREI:ApprenticeS15 e,CESSNA400Corvallis,TurboTimber1,5m,RareBEAR 0,9m,UMXTurboTimber,HabuSS50mm#BARCHE:USAF RescueBoat,Airboat tattica,HovercraftGriffon2000TDX,PT-109,LCM-3,rimorchiatorePaterson#TX:SPEKTRUM DX6i,DX8,FLYSKY FS-GT3B.
