Vecchio 15 febbraio 19, 00:36   #25 (permalink)  Top
buzz lightyear
Sospeso
Data registr.: 06-08-2017
Residenza: Nord-Est
Originalmente inviato da Ergonomix Visualizza messaggio
spero non succeda, ma se dovessero veramente passare le nuove normative , noi volatori di montagna, ci troveremo le ali tarpate e una serie di modelli fuorilegge inutilizzabili nelle nostre cantine.
Ma per favore…
Model aircraft
The impact of the new regulation on model aircraft operations is very limited and the hobby pilots will still be able to perform the same operations as they do today. EASA recognises the pro-safety environment created by model clubs and associations, documented in the positive safety records. In this way, several options for recreational activities are defined:
• operating as members of a model club or association that has received an authorisation from the competent authority which allows to deviate from the provisions of the regulation;
• operating in a special zone defined by Member States where certain requirements do not apply and/or where the operational limitations are extended, e.g. increased height limitation;
• and, in case you are not a member of a model club or association and there are no special zones in your vicinity, you can still operate your model aircraft respecting the operational limitations defined for C4 class.
Safe operation of drones in Europe
Update on EASA’s activities - April 2018
https://www.easa.europa.eu/easa-and-...il-drones-rpas
buzz lightyear non è collegato   Rispondi citando
