Originalmente inviato da Kat Sitwoy |
Caro Editore, mi dispiace dirtelo, ma i documenti ai quali fai riferimento non dimostrano affatto la tua interpretazione. Anzi, al contrario:
REGULATORY COMPLIANCE
Key elements of AMA’s Safety Code include the requirement to see and avoid manned aircraft and maintain model aircraft operations within visual line of sight.
In addition to operating within our safety programming, AMA members should comply with any and all applicable federal, state, and local laws and regulations.
SAFETY HANDBOOK - Academy of Model Aeronautics https://www.modelaircraft.org/about-ama/advocacy |
SEC. 349. EXCEPTION FOR LIMITED RECREATIONAL OPERATIONS OF UNMANNED AIRCRAFT.
[…] a person may operate a small unmanned aircraft without specific certification or operating authority from the Federal Aviation Administration if the operation adheres to all of the following limitations:
(2) The aircraft is operated in accordance with or within the programming of a community-based organization’s set of safety guidelines that are developed in coordination with the Federal Aviation Administration[…] https://www.modelaircraft.org/sites/.../files/100.pdf |
Recreational Fliers & Modeler Community-Based Organizations
https://www.faa.gov/uas/recreational_fliers/
FAADroneZone
https://faadronezone.faa.gov/
@ giocavik
Is a UAS the same as a model aircraft?
Congress defined a "model aircraft" as a UAS that meets all of the following:
Is capable of sustained flight in the atmosphere
Is flown within visual line-of-sight of the person operating it
Is flown for hobby or recreational purposes
Published 12/10/2018 11:28 AM | Updated 12/10/2018 11:28 AM https://faa.custhelp.com/app/answers...ne%20Questions |
If I'm flying my UAS or drone in my own yard, do I have to register it?
You will need to register your UAS or drone if it weighs more than 0.55 pounds.
Published 12/13/2018 09:20 AM | Updated 12/13/2018 09:20 AM https://faa.custhelp.com/app/answers...YURGUHgzN28%3D |
