Originalmente inviato da runnerfly67 Si c'è il manuale ma è molto scarno non entra con esempi nelle varie funzioni,io sto impazzendo,miscelo lo stick con l'alettone sx e va ,faccio una seconda miscelazione con l'alettone dx attivato sempre dallo stesso switch va il dx e non va più il sx.
questo è un esempio della spiegazione ,vai a capire cosa vuol dire + * : e come usarli.
The illustration above is an example of the “EXTRA MIXER” menu, to enter this menu press the “MDL” button followed by PgUp/Dn, then select “EX MIXER”. In order to meet the demands of accomplishing model customization, the user can customize the mixer setting to achieve configurations beyond the predefined transmitter mixes.
“TO”: Represents the channels that are mixed to. “MET”: Method, allows to change the insertion method of the signal produced by the mixer. + add signal produced by the “MIXER” to the selected output channel.
Page 66
* multiply by : replace with
“SCR”: Source, allows the user to assign a hardware input to operate the “MIXER”
“SW”: Switches, allows to assign an activation switch to turn the mix on or off, this can be done with hardware switches and logic switches.
“F.MODE”: Flight mode, allows to determine during which mode the mixer is active.
“L_W”: Left Weight, allows to set the limits of the travel range of the signal to the left
“R_W”: Right Weight, allows to set the limits of the travel range of the signal to the right
“OFF”: Offset, allows to change the centre (0) position of the signal.
“CUR”: Curve, allows to add custom curves created in “CURVE LIBRARY” in to the “MIXER”
Place the cursor to the column and the first slot in the list will light up. At this time press ENTER to select a slot and an operation box will pop up for edit and reset.
“Edit”: Edit the currently selected slot.
“Reset”: reset the currently selected slot. |
ho dato un occhiatina al manuale, non mi sembra diverso cosi tanto da altri programmi, NON E ANCORA ARRIVATA parlo senza radio in mano ci son MOLTE cose che che nn servono a nienti ma ad ess: alett.diff. e come al Turnigy, bty betterfly, e uguafe, come si imposta il nome del modello, uguale= parlo dell' originale, mentre non ho trovato niente che possa spiegare OPENTX , e i tutorial sono in inglese, tedesco, giappa o cinese. Ciao Lele
