Originalmente inviato da pikemax La Fai considera ai fini del carico alare tutte le superfici, anche la parte di ala e timone che attraversa la fusoliera. È una regola che impedisce ai furbetti di inventare astruse geometrie senza pagar pegno.
I fabbricanti la usano per i loro scopi commerciali. |
...grazie Max, molto chiaro.
SC4_Vol_ABR_16
1.4 DEFINITIONS OF EXPRESSIONS USED FOR MODEL SPECIFICATIONS AND RULES 1.4.1. Surface Area
a) The surface area includes the total surface of the wings and that of the horizontal or oblique stabilising surface or surfaces. The surfaces taken for calculation are the orthogonal projection on to a horizontal plane of the surfaces in question with each surface at zero incidences.
b) When wings or stabilising surfaces are built into the fuselage of the model aircraft the surface taken into account shall include that area contained within the normal contours of the flight surfaces extended so as to meet at the plane of symmetry of the model.
