Vecchio 26 febbraio 16, 19:14   #10 (permalink)  Top
klamath
Moderatore
L'avatar di klamath
Data registr.: 20-09-2005
Residenza: ɐuƃoloq
Invia un messaggio via ICQ a klamath
• Industrial high resolution screen (480*272), readable outdoor
• All CNC gimbal with 6 ball bearings, accuracy hall sensor and extensible by stick ends
• Inbuilt GPS module
• Inbuilt wireless trainer system
• Inbuilt 6-axis sensors (3-axis gyro and 3-axis accelerator)
• Two types of aluminum panels (matt or texture)
• 16 channels (up to 32 channels)
• Audio speech function
• Full telemetry and real-time data logging
• Antenna detection and SWR warning
• Receiver match
• Newly designed internal RF module IXJT with lower latency and higher stability
• Inbuilt antenna as default, external antenna could be added (for internal RF module)
• External module bay
• Safe power switch with integrated strap base
• Two types of trainer ports
• MP3 player
• Haptic feedback
• NiMH batteries with inbuilt charging circuit
• 6 position encoder for easier flight modes switch
• FrSky FrTX operation system installed as default, Open source firmware supported
* Voice recognition might be applied on certain configuration later.
* FrSky reserves the right to change the hardware, software and specifications without notice.
mi gustano i gimbal al cnc
riguardo le funzioni vocale non ho capito se la horus avrà un sintetizzatore vocale?
klamath non è collegato   Rispondi citando
