Vecchio 07 settembre 14, 20:36   #7 (permalink)  Top
Modelero
L'avatar di Modelero
Data registr.: 06-07-2014
Residenza: Palazzolo s/O
dati del servo installato:
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.21sec/60° at no load
Operating Speed (6.0V): 0.16sec/60° at no load
Stall Torque (4.8V): 45.82 oz/in. (3.3kg.cm)
Stall Torque (6.0V): 56.93 oz/in. (4.1kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
Continuous Rotation Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 8mA/idle and 150mA no load operating
Current Drain (6.0V): 8.8mA/idle and 180mA no load operating
Dead Band Width: 8usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: Nylon
Connector Wire Length: 11.81" (300mm)
Dimensions: See Schematics
Weight: 1.6oz (45.5g)
Modelero non è collegato   Rispondi citando
