Vecchio 23 giugno 14, 16:42   #10 (permalink)  Top
alex007
Data registr.: 07-09-2009
Residenza: Bologna
Alla fine prendo
1) il primo motore:
AX-2306N-1300
Micro brushless motor
Comes with stick mount, as shown.
Spec.
Kv: 1300rpm/v
Lipo Range: 2-3 cell
Suggested prop: 8x4, 8x3.8
Best current range: 5~8A
Weight: 37g
Stator: 23 x 6mm
Test Data;
Battery: 11.5v
Current: 8.55A
Propeller: 8x4
Thrust: 537g
Speed: 9950rpm
2)Questo regolatore
Features:
• Smooth and linear throttle control
• Fast response to throttle input
• Atmel MCU
• Stalled motor protection
• Throttle signal lose protection
• Safe power-on (throttle lockout)
• Support 480Hz+ high refresh rates (up to 499hz)
• Compatible with programming card
Specs:
Constant Current: 10A
Input Voltage: 2-3 cell Lipoly
BEC: Yes (linear) [Remove middle wire to dissable]
BEC Output: 5V/2A
PWM: 8 KHz
Max RPM: 240,000rpm for 2 Pole Brushless Motor
PCB Size: 22mm x 17mm
Discharge Plugs: Male 2mm Bullet Connector
Motor Plugs: Female 2mm Bullet Connector
Weight: 16g
3)
10 eliche 8x3,8 e 6 eliche 8x4
dici che va bene? il costo totale è di 19,70€
alex007 non è collegato   Rispondi citando
