Vecchio 24 febbraio 14, 10:38   #21 (permalink)  Top
minulino
Data registr.: 07-02-2012
Residenza: bagni di lucca
esiste la nuova versione New Rcexl Opto Gas Engine Kill Switch V2.0
queste sono le specifiche :
1. Includes a remote mountable bright LED to indicate when the ignition is armed.
2. Fiber Optic Coupled Input/output.
3. PIC12F675 Controller.
4. Li-Po/Li-ion/A123/Ni-Mh/NiCad Input.
5. Up to 20 Volt 16 amp MOS-FET(IRF7456) output.
6. Low to 3 Volt 3 amp OUTPUT.
7. Low Voltage Drop-Less than 150mv.
8. 100% Surface Mount Technology.
9. Heavy Gauge Wires, universal connectors.
10. Small and light weight-only 0.3 OZ!(8g).
11.Shut down the transmitter power or receiver to cut off automatically when kill engine.
This device plugs into a spare receiver channel.
This is a must have safety device for any gas powered plane!
This device allows you to safely kill your engine at anytime (on the ground or on the air) or when out of control also allows.
Note: The kill switch not including BEC Function(Battery Eliminator Circultry).
minulino non รจ collegato   Rispondi citando
