il problema è che 2 ali da server in serie a 24V non bastano, devi farlo lavorare in tensione, ne servirebbero almeno 3 in serie
iCharger 4010 Duo Specifications
Input Voltage: 9.0-50 Volts
Max Input Current: <65 Ampc
DC Charge Current Range: 70A@Syn. Mode - 40A@Asyn. Mode
Amps Discharge Current Range: 0.05 7.0 Amps
Maximum Charge Power Capacity: 2000W (Channel 1400W @input > 23.5V)
Maximum Discharge Power Capacity: 200W (Channel 130W)
Maximum Regenerative Discharge Capacity: 2000W (Channel 1400W)
Current Drain for Balancing: 2.4A@Syn. Mode 1.2A@Asyn. Mode
Balance Accuracy: <10mv
Lithium (LiPo/Lilo/Life) battery cell count: 1-10 series (Per Channel)
NiMh/NiCd Battery Cell Count: 1-25 Series (Per Channel)
Pb (Lead Acid) Cell Count: 1-18 series 2-36v (Per Channel)
Battery Setup Memories: 64
Intelligent Temperature Control: Yes
PC Connect: USB Port
Weight: 1.47 Kg
Dimensions (LxWxD: 210x140x81
Ultima modifica di klamath : 13 gennaio 14 alle ore 23:53 |
