Vecchio 10 dicembre 13, 10:35   #2 (permalink)  Top
domenicopresta
Sospeso
Data registr.: 07-12-2009
Residenza: caltanissetta
aiuto nella conversione ..
ho creato un'ala semplice in gmfc ...
l'ho salvata ...
ma cut2G mi combina solo questo :
%% G-Code prepared by cut2G, version 1.3
%% copyright G Sokoll 2012
%% SET LENGTH UNITS
%% G20: INCHES
%% G21: MILLIMETERS
G21
%% SET CUTTER COMPENSATION
%% G40: OFF
%% G41: ON LEFT
%% G42: ON RIGHT
G40
%% SET TOOL LENGTH OFFSET
%% G43: INDEX IN TOOL TABLE
%% G49: NO OFFSET
G49
%% SET PATH CONTROL MODE
%% G61: EXACT STOP
%% G64: CONSTANT VELOCITY
G64
%% SET DISTANCE MODE
%% G90: ABSOLUTE
%% G91: INCREMENTAL
G90
%% SET FEED RATE MODE:
%% G93: INVERSE TIME MODE (MOVES PER MINUTE)
%% G94: UNITS PER MINUTE (PER SECOND ???)
%% G95: UNITS PER REV
G94
%% Axes Naming convention:
%% - Left hand axes = X, Y
%% - Right hand axes = A, B
%% Turn off wire heat
M5
%% End of file. Bye.
dov'e' che sbaglio ?
domenicopresta non รจ collegato   Rispondi citando
