Discussione: Dragonfly #35 3d
Vecchio 03 febbraio 05, 11:48   #3 (permalink)  Top
fonzinieto
Data registr.: 08-12-2004
Sul sito del produttore cinese http://www.walkera.com/ si può scaricare il filmato dell' ely in volo , sembra molto stabile ... cosa ne pensate ?
NB: Per vederlo ho dovuto scaricare Real Player gratuito
Function and Feature
The R/C helicopter 35# is miniature electric-powered helicopter which boasts all the performance and flight handling of much larger models. It is controlled using collective pitch and a Bell/Hiller main rotor mixer linkage. i.e. we have not adopted any compromises which would have an adverse effect on flight control. The result is that the R/C Helicopter 35# be flown in quite strong winds without problems, in spite of its diminutive size .
The potential flight time per battery charger about 15 minutes duration is possible under normal conditions if the recommended Lipo battery is used .
The motor drives the main rotor by means of a single-stage gearbox with an integral autorotation freewheel by no means a standard feature in this size of model. The rotor is driven directly by the motor via a ball raced fibre shaft.
No.35 Plane Model
Standard configure:4ps minc 9g gyro,receiver、speed controller,6-channed transmitter、10.8V/650mAh Ni-MH battery、Charger,foam blade,foam blade。
Fuselage overall length:750mm
Total width:320mm
Main rotor diameter:630mm
Tail rotor diameter:145mm
Flying weight:555g (NI-NH Battery)
Motor :380 (normal or brushless)
Servo: 9g
Flying time: NI-NH (flying 4-8minutes)
Code:Z30350104
Price(USD):220.0, Not include order price.
fonzinieto non è collegato   Rispondi citando
