Vecchio 18 agosto 13, 18:49   #8 (permalink)  Top
EttoreM
L'avatar di EttoreM
Data registr.: 25-05-2013
Residenza: Polignano a Mare
Ecco qualche info in più:
This M-Spec version is very unique as it is a pre-built 1/8 Electric Buggy with full blow race settings….the shocks, diffs, camber, caster, toe ins….etc. are straight from our factory drivers and incorporated into a race ready build.
The ECO is equipped with special battery tray which will accept either 2- 2 cell LiPo batteries in a staggered mounting position for optimum weight distribution or a single 4 cell battery…the choice is yours! A new designed motor mount which has beefed up with so you can run the bigger and fast electric motors without losing gear mesh or without the flex which causes motor and mount breakages. There is a heavy duty sliding motor mount that is anchored down with 4mm screws for extra strength. A newly designed ackerman plate with adjustability for smooth to aggressive steering. A stylish cab forward body with raised sides on the rear portion for additional rear traction.
MBX7 ECO M-Spec Features:
Heavy duty aluminum motor mount housing A (E2122A)
Heavy duty aluminum motor mount B (E2122B )
Small composite molder receiver and servo mount (E2313)
Multi-adjustable ackerman plate (E2312)
Stylish mid-cab X7 body (E1045)
3mm A7075 hard anodized chassis
Lightweight conical diff gears
Straight cut conical and ring gears
Specially designed front upper and lower suspension arms, front hub carriers, rear suspension arms and hub carriers
15mm hard anodized threaded shocks with 3.5mm shock shafts and rubber shock boots
5mm A7075 aluminum front shock tower
4mm A7075 aluminum rear shock tower
5mm A7075 aluminum lower suspension mounts for optimized geometry
High down force white wing which is adjustable forward and back.
EttoreM non è collegato   Rispondi citando
